You’re doing it wrong…
19394969899115
    F1nut Posts: 51,894
    edited August 2025
    NM...not worth it.
    Post edited by F1nut on
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,803
    edited August 2025
    ^^^^Looks like they were going to knock out that curb to fix the puddle. The blade doesn't look bent or worn out and they're not cheap. What am I missing here?
    Maybe the ground beneath is eroded, causing concrete to settle against the blade.
    That blade is from a walk behind road saw and I've buried those blades to the arbor many times over the years. Same with a back breaking demo saw. Never once got one stuck to the point of removing the saw.
    My best guess is it's a set up pic as that blade isn't stuck.
    This is the man who probably lost or set up the blade.
    Q
    Post edited by BlueBirdMusic on
    Harry / Marietta GA
    SCompRacer Posts: 9,121
    edited August 2025
    From facebook....
    "I woke up this morning to the sound of liquid concrete bubbling up through my toilet like some kind of construction nightmare from hell. Turns out the contractor we hired to build our retaining wall at the summer home decided to dig without checking where our sewer line runs, hit it with his excavator, then tried to "fix" it by pumping concrete directly into the broken pipe."
    F1nut Posts: 51,894
    Wow
    nooshinjohn Posts: 25,962
    SCompRacer wrote: »
    From facebook....
    I think you have found the very essence of what this thread is all about. Outside of winning a Darwin Award, this has to be the dumbest crap I have ever seen.
    treitz3 Posts: 20,054
    One day, many decades ago, I was watching TV, when I heard a very loud "whoosh", followed by strange noises and a gawd awful loud sound that was definitely different. It sounded like 10 million gallons of water being released from the largest dam there is.
    So, I hike back into the woods to see what's going on, as I start to hear fire trucks in the distance. Some contractor had hit a gas main right in front of an apartment complex building with a huge backhoe. 12 apartments were a total loss and others were scorched enough to not be livable anymore.
    Yes, the line was clearly flagged by the utility department. The incredibly fast rush of fire coming up from the ground shocked me, and produced a sound I'll most likely never hear again. Words can't really describe it. The beam of fire shot up at least 60 feet in the air.
  • daddyjt
    daddyjt Posts: 3,120
    ― Aleksandr Solzhenitsyn
    That'll hold it for a while.
    edited August 2025
    Temp repair until they find a 'round tuit' to fix that rear main seal leak properly... Cork plug used for quick no tool drain.
    mhardy6647 Posts: 35,161
    OleBoot wrote: »
    Those have to be boiled for a long, long time to make a good soup.
  • daddyjt
  • Geoff4rfc
    Geoff4rfc Posts: 2,907
    SCompRacer wrote: »
    From facebook....
    It's okay man, you can tell the truth.....just another bad taco bell night
    Set up: 11.2 HT + 2ch
    Cables: Mogami AES from CDP to DAC - AQ McKenzie XLR from DAC to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 707 power conditioner.
    billbillw Posts: 7,697
    SCompRacer wrote: »
    The accident attorneys had fun with this accident...
    The owner/captain was a CEO with deep pockets. I'm sure he settled.
    https://www.hickeylawfirm.com/blog/serious-boat-crash-leaves-two-passengers-with-serious-life-altering-injuries/
  • skipshot12
    skipshot12 Posts: 2,074
    WOW, he'll need deep pockets with those injuries.
  • BlueBirdMusic
    Harry / Marietta GA
  • Jetmaker737
    Jetmaker737 Posts: 1,123
    F1nut Posts: 51,894
    Oops!
    edited August 2025
    Guessing that's a failed drive test.....
    SCompRacer wrote: »
    or Zen Expert Master level... could go either way.
    looks like they passed the CA CDL test,,,
  • BlueBirdMusic
    Harry / Marietta GA
    I was gonna say, "Oh NO!"......but then I saw it was a Ford. >:) Poor pool.
