New To Home Theater: Need Help Calibrating/Setting Crossover Frequency
  • ravaneli
    ravaneli Posts: 530
    edited March 2012
    so the notes over 60 came from the speakers?
    Perhaps set all speakers to 80 then.
    You must make sure that the speakers can play the bottom end of the signal that you are routing to them. For example, if 50 hrz is sent to them but they cannot play it, then your crossover should be no lower than 60
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • Hammer50X
    Would love some guidance with the following set up, trying to integrate in my small/medium size living room set up. 15 feet long 13 feet wide and 8 foot high
    Receiver: Onkyo TX SR393 5.2
    Front left and right colon Polk audio T50 tower speakers
    Center channel: Polk audio Blackstone TL1
    Rear speakers: 1990s KLH 4 1/2 inch woofer bookshelf speakers with bass reflex
    Subwoofer colonJamo C910
    Current settings
    Front left and right: 80 Hz
    Center: 150 Hz
    Rears: 90 Hz
    Subwoofer el Effe 120 Hz, crossover max on the back of the subwoofer
    Thoughts and guidance would deeply be appreciated😎
  • Hammer50X
    Forgive my mistyping, legally blind using dictation that doesn’t always playback well with VoiceOver🌧
    : not colon😎
    LFE 120
    F1nut Posts: 52,360
    I suggest you get a proper center channel before anything else.
  • Hammer50X
    FYI… I don’t have the capital to get a “proper Center channel : Some of us just starting out can’t afford upgrade after upgrade after upgrade, just reality not coveting what others can/cannot do.
    So my inquiry stands with what I have not with what I do not.
    Thanks 😎
    billbillw Posts: 8,172
    Doesn't that receiver have a room calibration feature? Use it. Personally, I think it works best to have the subwoofer crossover no higher than 80Hz (in the receiver settings) and have the speakers set to the same.
    pitdogg2 Posts: 27,847
    billbillw wrote: »
    AccuEQ Room Calibration, yep
  • Hammer50X
    Yes, ran the calibration, it seems to be all over the place, putting my front speakers which are rated down to 40 Hz up at 200 Hz
    Center lower than what it’s rated, typically should be around 125 Hz but at 100hz, there is no setting in avr other than every 2ohz then 50hz increments
    Rears are rated at 70 Hz, reads them down at 50 Hz
    Sub too boomy need to back it off
    Just confusing, don’t want to overload the AVR and the speakers
    I'd encourge you to make sure ANYTHING that can make ANY noise is OFF. You need a DEAD quiet house for most to work correctly. I will tell you the super tiny hum my refridgerator made was enough to foul up my results. The microphone also works much better it it is raised up on some sort of tripod. If it is sitting on a couch cushion that can also mess up the results because of reflections or soaking up the tone generated. Regardless your receiver is going to be overwhelmed, It is only rated at 80WPC at only 2 channels. Running the extra channels will drastically reduce its ability to provide enough power to the speakers as it is. You may be down to as little as 25-30 WPC and very close to clipping the signal during movies or surround music.
  • Hammer50X
    Thanks, ac and other noise producing off. Don’t have a tripod, not purchasing at this time.
    Basic/first time system. Recognizing there will be settling for good enough.
    Hoping for general guidance for what I have😎
    With the lower end room calibration in these receivers, most of the time, you are better to manually set the crossover points to 80Hz as I mentioned. Then it will apply EQ to balance things. They almost never get the subwoofer volume correct either. I always set that using a sound meter. The key is to run the calibration to get the distances and make sure everything is in phase, then override the crossover points and sub volume. Often, I double check the distances with a tape measure to verify that nothing funky happened.
    F1nut Posts: 52,360
    edited August 2025
    Hammer50X wrote: »
    Thanks 😎
    Well, excuse me for not being a mind reader. Good luck.
