You’re doing it wrong…
Lewis Hamilton vs Bubba Wallace - F1 vs NASCAR Monza - 2025 Season
https://www.facebook.com/share/v/1BfNzBi8Jq/Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
― Aleksandr Solzhenitsyn -
Does the factory have public tours….asking for a friend2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Does the factory have public tours….asking for a friend
and samples....... -
and samples.......
Maybe draft?
Mmmm, cold and on tap...
"I'll order the buffet, please".
Some argued that this was OK, depends on code so maybe it's right somewhere?
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »Some argued that this was OK, depends on code so maybe it's right somewhere?
The skylight's the best part.
I'm pretty sure the joist inserted into the beam (assuming they are secured somehow??) isn't going anywhere
The floating girder/header on the other hand is... Concerning- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'd be fine if the joists were strapped to the I-beams, but those could slip with settling, or in quake prone areas. -
for sure, if they are just chilling with gravity... will work great until it doesnt :-p- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Talk about "room filling":
If done properly, there will be blocking/noggins secured between each joist that locks everything in place (in the I-beams, and along the joists span).
If you want to seen this being done, the YT channel "Escape to Rural France" has shown this on a pretty large scale as he rebuilt the floors in his chateau.
https://www.youtube.com/@escapetoruralfrance
I'm not saying the above picture makes me feel good, the work looks fairly sloppy and some very, very questionable framing choices. But in general, there is nothing wrong with notching joist directly into an I-beam, when done properly. -
and samples.......
My ex was breast feeding at the end of my racing career and was producing way more than consumption and asked me what to do......I'm scratching my head, gee honey I don't know....wait, give it to me....she said why? I said, you'll see.
I was at 195, I put on 5lbs of solid muscle from my workouts......yeah baby, serve it up -
Standby: LSi9s with VR3's Fortress mods -
(ASR)
Milk it for all it's worth somehow takes on a whole new meaning...
And there you have it. In my case I've been around muscle guys enough to know that some would sell their very own soul or whatever else it takes for ill gotten gains.
The caption was sewer backing up after high voltage underground mains updated... Mole (trenchless) method used.
