You’re doing it wrong…
    VR3 Posts: 29,639
    It is
    VR3 Posts: 29,639
    I'm not an electrician but bonding the ground to the neutral at the device may cause the circuit breakers to not operate properly.
    Residential the neutral and ground are bonded at the panel for a low impedence path in the event of a short
    SCompRacer Posts: 9,166
    edited July 2025
    Yup. "The breaker trips immediately when we plug it in....."
  • Upstatemax
    Upstatemax Posts: 2,842
    VR3 wrote: »
    You can connect them in the panel, not at the outlet/appliance.
    It can cause ground loops, or energize the ground/neutral wire.
    Best case, it can cause equipment damage. Worse case, a fire.
  • tonyp063
    tonyp063 Posts: 1,149
    Courtesy of my local multi-ethnic market
  • skipshot12
    skipshot12 Posts: 2,110
    treitz3 Posts: 20,222
    In the Korean language, the word bong can mean a stick or rod.
    txcoastal1 Posts: 13,519
    Fish sausage from Wang
    pitdogg2 Posts: 27,623
    I'm scared to ask what is the "original" flavor....... :s
    For some reason, the customer complained that all of the switches were tripping in the house when this was turned on. Some people are so smarts....I never knew switches could trip!
    Dear lawd, some people's kids...
    But, but...I found someone who could install it cheaper!!!
    treitz3 wrote: »
    Holy bat sneakers!!! That is insane!
    treitz3 wrote: »
    I wouldn't be one bit surprised if that squeaked, not one bit....
    *Shakes head*
    Viking64 Posts: 7,721
    The fact that they missed the opportunity to put a smile under those eyes is baffling.
  • bcwsrt
    bcwsrt Posts: 2,598
    edited July 2025
    treitz3 wrote: »
    *Shakes head*
    Great canvas for some Minion art!
  • CGTIII
    CGTIII Posts: 1,265
    bcwsrt wrote: »
    Reminds me of the hardware bins left behind in the shop my Mom later had an antique store. One was marked "ruffin nals."
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
  • ken brydson
    ken brydson Posts: 9,065
    edited July 2025
    Morgan Wallen concert last night. No i wasn't there
    Yeahhh....Noooo!!!
  • daddyjt
    daddyjt Posts: 3,197
    The longer you look, the worse it gets…
    ― Aleksandr Solzhenitsyn
    When you flip the little flipper to flush that toilet, a red light that reads "TILT" flashes on and off repeatedly.
  • Geoff4rfc
    Geoff4rfc Posts: 3,014
    edited July 2025
    SCompRacer wrote: »
    Is the tire mounted backwards? Or have I just never seen a caliper mounted to the front of the wheel rotation?!
    Wait, just what the hail is going on here?
  • Geoff4rfc
    edited July 2025
    daddyjt wrote: »
    What's the issue here??? You pee and ****, hoping your aim is spot on, then turn on the valve to the water line to hose it down, which also doubles as bidet......looks like an Aggie toilet/bidet (Texas A&M). Those Aggies really know how to improvise and cut corners.....and it shows
    VR3 Posts: 29,639
    The good news is you won't be able to complain about the plumbing issues because you will be falling thru the floor
    Who needs floor joists....
