LSiM 706C Compatible Tweeter Replacement
crinklestein2000
The original tweeter for the LSiM 706C is no longer available from Polk and it's not on Ebay at the moment. Mine is completely dead. The model number of the stock tweeter is RD2513-1. However, looking on Ebay, the RD2513-1 is not available at the moment and there are similar looking tweeters with different bezels available under model numbers RD0517-2, RD0517-8 and RD0518-2. The bezels can be removed and the tweeter looks like it'll fit perfectly. Has anyone used any of these as a replacement or is there another brand that people have used that they've had success with? I think it's crazy for Polk to no longer support or provide parts for one of their flagship series and tell us to rely on Ebay.
I solved my problem. I bought a Peerless Tympany tweeter from Parts Express for $30. But it required minor modifying. The new one typically mounts from the outside but the Polk requires it to be mounted from behind. After taking out the OEM tweeter I had to end up butchering it. I took out the three screws on the front, I cut out the surface material and removed the cap. This cap has the the screws on the sides that need to attach to the standoffs on the front panel.
I used my Dremel to grind away the inner circle to make it wider enough to fit over the back of the new tweeter. Place the new tweeter in place and add a little bit of foam gasket to perfect air leaks, slide the modified bracket over the back of the tweeter, and screw it down. It fits perfectly and looks amazing. There's no way to know that this isn't OEM.
It now sounds absolutely amazing and maybe this new tweeter will last longer than the OEM tweeters seen to last.
I hope the Peerless tweeter holds up for you,I tried to substitute them in my lsim 707s,they didn't hold up,I'm looking at the Morel ET 448 as a possible solution.
Did you ever replace the tweeter with the Morel ET 448? if so what was the final result, sound wise? -
You can get it from lsim 704.
So these tweeters are unobtanium now?
Better off load my 706 soon so someone can blow it .VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
