Rockford Fosgate RF 2000 home amplifier.
daddyjt
daddyjt Posts: 3,120
edited July 2025 in Electronics
Yes, you read that correctly - HOME amplifier.
Having been a teen in the 80’s, I have always been a fan of Rockford Fosgate car amplifiers. Their innovative MOSFET designs were very innovative in their ability to deliver prodigious power from small chassis, with little heat, and run stereo AND mono AT THE SAME TIME. Indeed, I’ll never forget a display vehicle in the Car Concepts (SLC, 1989) showroom. It was a converted hearse (a Lincoln, IIRC) that was running THIRTEEN speakers at once, from a single Punch 45. That’s four sets of 3-way separates and a 12” sub on an amp “rated” at 22.5 wpc - and it sounded spectacular! Now granted, the Punch 45 was significantly underrated, and that amp routinely measures at 35+ wpc, but still… and the 45 was the smallest amp in the Rockford stable - the lineup at the time being the Punch 45, Punch 75, punch 150, Power 300, Power 650, and the 30” long Power 1000.
Well, unbeknownst to me until this very evening, Rockford Fosgate produced a VERY short-lived run of home amplifiers, patterned after the Power 1000 - The RF 2000. And the numbers it drove from a ridiculously small (but heavy) chassis are indeed very impressive. I won’t spoil the video, but take a look…
https://youtu.be/Z-Dz07Rm7aA?si=kUAx_drbn1vTPAOr
― Aleksandr Solzhenitsyn
    F1nut Posts: 51,893
    I had a 4 channel Class A Soundstream back then. Righteous!
    pitdogg2 Posts: 27,178
    edited July 2025
    That is a very cool amp! I had no idea.
    That is a pretty huge torrid and massive caps to go with it.
  • daddyjt
    Sound stream was solid stuff indeed. My first “real” car amp was an Orion 225 HCCA, before I dove head first into Rockford gear….
  • daddyjt
    Yea, HUGE transformer and caps. I can’t help but wonder if the test would have been different if the amp had a fresh recap - I mean those caps are over 35 years old…!
    edited July 2025
    daddyjt wrote: »
    You know it does make you wonder.
    When I called the company that refreshes my Aragon 8008bb that Indy labs (new Aragon owner) recommend as they do not do anything with the older Mondail amps. The recommended company told me that the 4 X CORNELL DUBILIER
    35,000 µF 80 VDC Rarely needed replacement. BUT if they did replace them at my request they were $350 for 4 That was 4-5 yrs ago, I thought that sounded expensive, who knows. In my research I never found any to buy on my own.
    CORNELL DUBILIER
    04-1012
    DCM353U080CC2B 35,000 µF 80 VDC
    -10% +75%
    -40°C TO +85°C
    MADE IN USA 658-9831-834
    That is everything off the side of one.
    That -10% to +75% is a head scratcher 😂😂
    Post edited by pitdogg2 on
  • daddyjt
    daddyjt wrote: »
    35,000 µF 80 VDC Rarely needed replacement. BUT if they did replace them at my request they were $350 ea. That was 4-5 yrs ago, I thought that sounded expensive, who knows. In my research I never found any to buy on my own.
    CORNELL DUBILIER
    04-1012
    -10% +75%
    -40°C TO +85°C
    If I were to attempt a recap on the RF amp, I’d create a bank of 5 of these per large cap for 41,000uf. I’d have to measure, but it looks like there’s room. Cost would be $55ish per cap, and they would have a much better ESR…:-)
    edited July 2025
    I just corrected mine. I've found them with mouser and others but must buy 30 at about $30 each.
    I'm not sure a bank would work on mine as they bolt directly to the board with the board resting on top of the 4 cans. I'm not dismissing your ideas you're more experienced than I am but the way the amp is built you would be redesigning the interior.
  • daddyjt
    That does get tricky when the mechanical hurdles that are more difficult to overcome than the electrical. Have you checked to see if something with slightly higher voltage or capacitance is available in a size that would fit?
  • invalid
    invalid Posts: 1,504
    There was also a Fosgate tube phono preamp made some decades ago also.
    daddyjt wrote: »
    No I have not. When I was looking a few years ago I was just looking at the value. It wasn't until Trey started the big ML amps that I screen shot that above to see if he ran across something similar in his shopping. Using that DCM number last night actually brought up suppliers that had them, none however sold individuals, just cases of 30 or more. I guess I could use the dimensions of that can to research larger values and temp in that size.
  • daddyjt
    Let me know the diameter, length and screw terminal spread, in mm and I’ll see what I can find…
    VR3 Posts: 29,505
    edited July 2025
    30 or more generally would mean it's being ordered from the manufacture and would have substantial wait times, ymmv
  • invalid
    The big supply capacitors last a lot longer than the small capacitors because they dissipate heat better and they usually have more airflow around them also. When Krell was still around they told me they very rarely had to replace big supply capacitors.
    VR3 wrote: »
    Correct, states 18 weeks.
