"Guts" that are filled w/ goodies like Solen, Auricap and Audionote. The stock tube compliment is Sovtek 6922/6DJ8 and JAN GE 5814/12AU7. I don't much care for the Sovtek, but they aren't too bad. Mullards or Telefunken will most likely reside in the 6922 holes while JAN Sylvania will be hopping in for some double team action.
BTW Mark - a promising career awaits you as the headline writer for the National Enquirer! I'll have their people contact your people, you can do lunch.
BMP - Fisher 1800(1965) It still works, but I'm going to get it recapped and spec'd anyways because it's just neat.
Nope.
*HINT* Full Range Driver
P.S. These KG4's are pretty killer. I think I may have to renounce my hatred of all things horn loaded....tubes warmed these right up, and the soundstage is better than expected and very forward.
I thought the speakers look like something Fischer put out in the 70's....hmmm. Though most of theirs had paper cone tweeters, they were built like frickin tanks.
Also, that strange color/surrounds make me think something JBL'ish....
makes me think of an old Advent speaker... but I don't know speakers from back then.
Quad of 6DJ8?
Cheers,
Russ
Nope.
ADS L810? Hell, I give up!!
Glad to see you getting horny.
McCormack TLC-1 passive preamp. There's actually more in there than I thought there would be.
A lot less going on in here compared to Doro's TOTL Cary pre.
A truly giant killer sounding system in my opinion. About $2,750 used on all gear. Only thing bought new was wire.
