1194195197199200202
  • JCL
    JCL Posts: 169
    It’s not a big deal to move the board it will just take about an hour for me. I have the one in the other speaker mounted on the side opposite the inductor. That one was harder to find a spot where the 6 required mounting screws and spacers would miss the grooves in the box wall and still be able to get my tools inside to mount the boards. If I take them apart I may just mount the crossover to a separate board and then mount that board to the cabinet. That will be easier since I won’t have to worry about all the spacers.
    Everything I read from the loudspeaker design cookbook is a minimum of 3” and 90 degrees should be good. I’ll probably just take the time this weekend and move it.
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • Dr_Wu
    Dr_Wu Posts: 356
    Finally introduced a tube component to the system, and am very happy with the pairing of a Joule Electra LA-150SE preamp with the Parasound A21. 95% of my listening is streaming Qobuz using my Lumin streamer as a preamp with its LEEDH volume control. I've been hesitant to put a preamp in the signal path for fear of losing clarity/resolution. Shouldn't have worried. If I've lost anything, I can't tell, and the fuller, richer, bigger soundstage I'm hearing now has me planted in front of the speakers and reluctant to move.
    Thanks to Rich Brkich, the "Joule Doctor" - so generous with his time and patience. Great transaction start to finish!
    treitz3 Posts: 20,092
    Well, I will say this. That's a fine sounding preamp. You choose....
    Wisely.
    Enjoy your new found sound. I don't know about others on this board, but I can't go without tubes in the main rig. I did that once, after having tubes in the rig for many years and couldn't stand it. It sounded like an all SS system. Anyhoo, congrat's to you on the aqusition of the Joule. Enjoy!
  • Dr_Wu
    Dr_Wu Posts: 356
    Appreciate your kind words, Tom. Your example, along with others here, convinced me to give it try. Glad I did, even if it took until now. Slow learner, I guess. :p
  • I moved my speakers about 20 cm from the walls and adjusted toe-in by 5 degrees. The soundstage got tighter.
  • jdjohn
    jdjohn Posts: 3,380
    edited July 2025
    Testing the vintage Yamaha A-760 integrated amp that I gave to my daughter, via a pair of Infinity RS5 speakers, on my 'side system'.
    Her former roommates cranked the volume to max on her system, which fried one of the vintage AR speakers she had, but we weren't sure about the amp. I *think* the amp is okay, but one of the AR speakers has toasted drivers. Right now, though, playing the amp through these Infinity RS5, it sounds mighty fine :) I love these speakers B)
    Dang, you have come a long way...
  • newbie308
    newbie308 Posts: 811
    Definitely worth the investment and effort! The Lumin DAC is really very good, but in a side by side comparison... There really is no comparison. There's so much more detail revealed through the Tri-vista. Deeper and more impactful bass and there's a sparkle in the high frequencies that makes everything sound more realistic. The sound stage is so precise that I found myself looking for the instrument that caught my attention. Considering that with all the new parts the DAC isn't even "burned in" I anticipate it is only going to get better. I'm a happy camper!
  • bcwsrt
    bcwsrt Posts: 2,492
    Took advantage of the rainy day to dust and detail everything, including the cables! Was overdue! Now it's time to sit back and enjoy for a while.
    Brian
  • Conradicles
    Conradicles Posts: 6,373
    Testing some VR3 pads...
    nooshinjohn Posts: 25,991
    edited August 2025
    edited August 2025
  • motorstereo
    motorstereo Posts: 2,359
    Congrats to you and it sure is a fine looking preamp. Looking forward to reading your impressions of it vs. the 2300.
  • Gardenstater
    Gardenstater Posts: 4,802
    edited August 2025
    Tested my buddy Steve's new acquisition in my system, which is a Denafrips Enyo 15th DAC ($699 not incl. customs duties), Regrettably my Squeezebox Touch with the Enhanced Digital Output app installed, did not recognize the Denafrips and we just got the spinning wheel and "DAC Not Recognized".
    But even using a 10 ft. USB printer cable from his HP 17 Laptop to the Denafrips and an iFi Gemini 1m USB cable to the Onkyo Integrated, it totally bested my SBT to iFi nano iDSD to Onkyo! I mean blew it out of the water! Even the bass was better. Low level cymbal details and resolution were incredible.
    I would upgrade to this in a hot minute if it had worked with the SBT output. Regrettably, we did not try the coax on the SBT to the Denafrips. Not sure why that would've worked when the USB didn't but we have to try that too. He took it with him back home which is pretty bad manners lol.
    https://www.denafrips.com/enyo
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    billbillw Posts: 7,754
    edited August 2025
    That is odd the SBT didn't recognize the Denafrips. Is that box supported with updates through the LMS/Lyrion project? My Daphile streamer basically uses the LMS engine in a very light Linux OS. It immediately recognized my Denafrips (although, mine is an older Ares II version).
    The difference when I upgraded to the Ares wasn't as obvious, but it did become noticeable after a few days. The low level detail and bass texture is what I picked up first. I think the change from the iFi portable DAC/Amp to the latest Denafrips Enyo is a bigger jump than it was from my Teac UD-301 to my Denafrips. They are definitely good quality products across the lineup.
  • Gardenstater
    edited August 2025
    billbillw wrote: »
    Unfortunately, the developer of the EDO applet is no longer in the Lyrion Community Forum so I won't hold my breath for any future tweaking of the code. I was advised that we could've also tried a USB hub (powered or unpowered) between the SBT and the DAC to see if it was tricked into working, in addition to the COAX digital output/inputs which is also supposed to be converted from an input to an output on the SBT by the EDO app.
    So you are using a SBT with some software called Daphile? I think that the function of recognizing the DAC would be a matter of the firmware of the SBT and not the streaming software and should work when you only have those two connected and powered regardless of inputs to the SBT but I could be wrong.
    I want to see if there is a list of known supported DACs by the EDO app and see if your old Denafrips is on the list. And yes I absolutely want one now, even despite the over $100 additional due to the tariffs, which that particular mfg. has decided they ain't gonna eat it.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    I actually use a little fanless thin client PC, which runs the Daphile software and connects via USB to the DAC. The playback is through using a phone/tablet browser. I've talked about it a few times in the Going Digital sub-forum. I wasn't sure if there was a connection between LMS/Lyrion and how the SBT functions, but I knew they were in the same ecosystem. Daphile uses the LMS/Lyrion engine.
    I'd definitely look on the used market to avoid the tariffs. I think the generational upgrades from Ares II > Ares 12th > Enya 15th version have been pretty small overall. In fact, the Ares II received a software upgrade after the Ares 12th was release to give the same basic features. The 12th had a better case and power supply design, but otherwise, it wasn't a huge jump. I haven't really followed the improvements since that time. For me, I saved a few hundred going with the used Ares II vs the 12th which was the latest at that time.
    Polished up what some folks here call, "The Bell".
    pitdogg2 Posts: 27,259
    Finally installed the aluminum tweeter bezels that @xschop so expertly made. I finally found a rountoit. Next up is to figure out a way attach the felt diffraction tweeter pads that @VR3 sent my way. I have some ideas, I'm not really sold on any yet.
    VR3 Posts: 29,540
    I recommend the 3m velcro strips, the hard hook side is all that's needed and the felt sticks right to it
    VR3 wrote: »
    That is on the list, thanks
    I had tossed around sewing on one side onto the felt at my upholstery shop. That it only needs one is a plus.
    VR3 Posts: 29,540
    Yes the wall strips are removable without damage... Works good!
    VR3 Posts: 29,540
    Very nice! Love the stands!
  • What stands are those? Do they have 4 springs between the spikes and the stand, for vibration isolation?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    No spring, just cheap Amazonic stands.
  • bcwsrt
    bcwsrt Posts: 2,492
    I like the in-wall rack! That's something you don't see every day. Beautiful setup! Rogue Pharaoh has some muscle, too. 👍
    Brian
  • @Conradicles Nice setup! I really like the wood grain on those speakers! I've been seriously considering a Rogue RP5 to add some tubes to my system. How do you like the Rogue you have?
