Amp / Pre I Really Like
kevhed72
Conrad Johnson MF 2200 and DeHavilland. I have had both for awhile now and never got around to posting about the combo.
The amp does run hot-ish and seems to be hotter on the left channel. Also, I would like someone with skills to install a removable IEC plug and heck...might as well as replace with TOL caps. I am a bit squeemish about doing this myself since I normally left the amp on and sometimes power down the pre. Any Polkies interested in upgrading the amp or recommendations on a good tech?
What state are you in/near?
Running hot-ish isn't a problem, but one channel running hotter than the other means the bias needs adjustment.
Looking at a pic of the rear it could be challenging to mount an IEC where the captive cord is, but I'm sure something could be figured out.
President of Club Polk -
. Georgia with an occasional trip to AR, KY, or AL.What state are you in/near?
You familiar with Benny in Atlanta? That's who I would recommend for your area. If you are close enough to North Atlanta, you could just drop it off and probably pick it back up within a week or two. That way, you don't run the risk of shipping.
If you are interested, I'll give you his contact information. Highly recommended.
That's who fixed my LSA Statement amp. He's a long drive from Kevin though. Benny is up on the edge of Roswell/Alpharetta. He typically has a 2-month wait as well. -
Yeah you should really expect minimum 90 days- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That is a very nice amplifier!
Benny figured out my preamp problem when nobody else could.Yep, my name really is Bob.
