Amp / Pre I Really Like
Conrad Johnson MF 2200 and DeHavilland. I have had both for awhile now and never got around to posting about the combo.
The amp does run hot-ish and seems to be hotter on the left channel. Also, I would like someone with skills to install a removable IEC plug and heck...might as well as replace with TOL caps. I am a bit squeemish about doing this myself since I normally left the amp on and sometimes power down the pre. Any Polkies interested in upgrading the amp or recommendations on a good tech?
    treitz3 Posts: 20,237
    What state are you in/near?
    F1nut Posts: 52,237
    Running hot-ish isn't a problem, but one channel running hotter than the other means the bias needs adjustment.
    Looking at a pic of the rear it could be challenging to mount an IEC where the captive cord is, but I'm sure something could be figured out.
  • kevhed72
    kevhed72 Posts: 5,195
    treitz3 wrote: »
    . Georgia with an occasional trip to AR, KY, or AL.
    You familiar with Benny in Atlanta? That's who I would recommend for your area. If you are close enough to North Atlanta, you could just drop it off and probably pick it back up within a week or two. That way, you don't run the risk of shipping.
    If you are interested, I'll give you his contact information. Highly recommended.
    billbillw Posts: 8,001
    edited May 2025
    treitz3 wrote: »
    That's who fixed my LSA Statement amp. He's a long drive from Kevin though. Benny is up on the edge of Roswell/Alpharetta. He typically has a 2-month wait as well.
    VR3 Posts: 29,658
    Yeah you should really expect minimum 90 days
  • Conradicles
    Conradicles Posts: 6,401
    That is a very nice amplifier!
  • muncybob
    muncybob Posts: 3,291
    Benny figured out my preamp problem when nobody else could.
    Yep, my name really is Bob.
