Polk crs+ Erse Super Q Inductor question
From the looks of it, Erse no longer sells these?? I found this site; can anyone tell me which one to purchase or point me to a site that sells the correct ones for the sub-bass drive. Thanks.
https://uscoils.us/super-q-coils/
    pitdogg2 Posts: 27,921
    edited March 2025
    https://uscoils.us/product/ussq55-18-17000/
    You'll need to unwind to the correct value of 16mH, so you'll need a pretty expensive meter to do it correctly. Just so you know, these can have a pretty good +/- factor. My 17mH pair one was over 20mH and the other about 15mH. It would not be wise to use a pair that far apart. So my tech made the 20mH match the 15mH so both were the same yet still under the needed 16mH. I in turn went with the C-coil 3yrs later and have been super happy. Spend once cry once go with the C-coil pair.
    Most of us have used these.
    https://www.hificollective.co.uk/catalog/000-6577-16mh-jantzen-c-coil.html
    https://www.parts-express.com/Jantzen-6577-16mH-14-AWG-C-Coil-Toroidal-Inductor-255-842?quantity=1
  • lms
    lms Posts: 54
    C-coil it is then. I have never installed these, but my guess is to not mess with the length of the coil. Any tips on connecting them or is it as straight forward as it seems.
    Thank much!
    edited March 2025
    lms wrote: »
    Thank much!
    I used male and female qiuck connects. I crimped and soldiered the spade (male) to the coil and made a length of good quality silver coated copper wire crimped and soldiered the female quick connect to put the C-coil as far as I could from the XO. You however do not have much room in the CRS cabinet. The C-coil will need to be mounted to the cabinet, you can use 1 inch plastic clamp hanger
    https://www.homedepot.com/p/Cantex-1-in-2-Hole-PVC-Clamp-Strap-For-use-with-Schedule-40-and-80-5-Pack-R5133738/202043223
    OR something like this if you can find them large enough
    https://www.homedepot.com/p/Gardner-Bender-Plastic-Clamps-Black-4-Pack-PPC-1600UVB/100148325
    Brass or stainless screws may be best.
    @VR3 may have a better suggestion
  • lms
    lms Posts: 54
    I purchased some solen caps, two, 130's. Those will not be mounted in the same place as the three caps that are there now. Do you think I could mount the C-coil in that space since those caps will be moved?
    Thanks.
    lms wrote: »
    Thanks.
    I wouldn't, there is a strong field around that monster.
    VR3 Posts: 29,763
    I usually mount it to a board and mount away from everything
  • lms
    lms Posts: 54
    edited March 2025
    Oh, my lord, the coils are that big? And those crossovers, etc. are unreal.
    How about where the super Q is mounted in this pix, or in that gen area?
    They are pretty heavy, I preferred mine on the floor of the cabinet in the corner far away as I could get it. My cabinet is much larger than yours.
    I'll defer to @VR3 he has used them far more than I.
    VR3 Posts: 29,763
    The c coil needs to be as far away from other inductors as possible
  • lms
    lms Posts: 54
    Thanks.
    Should I unwind the old wire from the crossover mount?
  • lms
    lms Posts: 54
    And what caps are you using, they look like clarity caps, but i don't see the values that would get one to 260?
    lms wrote: »
    Thanks.
    I just unhooked mine and left it alone.
    lms wrote: »
    The picture @VR3 posted looks to be for the SRS 1.2 NOT a SDA-CRS model. He is a big Clarity cap fan.
    If you would like to save some money I'd be willing to let go of the Erse super Q's I have. Send me a PM and we'll chat.
  • lms
    lms Posts: 54
    Pitdogg is selling me his Erses, so problem solved. Solens ordered as well. Everything else in those boxes has been upgraded, except the TL mod. I even added the baffles that Westmassguy came up with. Right now, I'm fine with the 194's, been in them for years. Maybe down the road I'll take care of that. Granted, my crossover job/parts/etc. looks nothing like VR3's, but it gets the job done.
    The biggest bummer, I just moved. I had a great spot in my last listening room, long walls, nothing next to speakers and the soundstage was unreal. The new spot, well, it's not at all the same. But I still get some of the magic.
    Thanks much all!
    Do you have extra hook up wire ? If not I could send some with the inductors. The inductors will come with both sets of spades.
  • lms
    lms Posts: 54
    I have some, but I was just about to order some more, so I'll take some if have a little to spare.
    Thanks again!
  • lms
    lms Posts: 54
    The solens arrived, my god these are big. Putting these in the small cabinets wasn't easy. I mounted them on a board with zip ties and attached them to the floor of the speaker, right next to where the interconnect wires are and out of the way of the PR. I'm not sure where I'm going to mount the erse, my thoughts are to the back of one of the baffles. It's getting cramped in there though. We will see how this works out.
    VR3 Posts: 29,763
    You can always go to an external back pack type build
  • lms
    lms Posts: 54
    edited April 2025
    Alrighty then. Found a spot for the inductors and installed one in the right speaker and tested. My testing is basically turning the balance knob back and forth, over and over, sitting in chair and listening. High tech! Now, correct me if I'm wrong, but it sure sounds like the bass, to a certain degree because it's just the dimensional x-over, is tighter and well, not as deep as the speaker I didn't change. What has everyone else experienced with these inductors?
    I also tested the same way with the solens in one, not the other, and I can clearly tell after they burned in for a day, that the overall sound from that driver is clearer.
    F1nut Posts: 52,406
    is tighter and well, not as boomy as the speaker I didn't change.
    Fixed it for you.
  • lms
    lms Posts: 54
    Fixed it for you.
    Thats what I was looking for.
    It usually takes a good amount of time to burn in new caps. You may experience great sound then OMG WTH did I do moments before you go, MAN this is sweet !
  • lms
    lms Posts: 54
    Which is what I'm doing right now. I have my rig on 24/7 right now, has been this way for 4 days as I just installed some Odam caps and some better resistors in a tube pre I have. I'll install the other inductor tonight, button them all up and let them marinate until this weekend.
  • lms
    lms Posts: 54
    Uh oh, did I make a mistake? I was just looking through the different schematics and my speakers are blade, blade. In other words, did I just install the wrong inductors?
  • Gardenstater
    Gardenstater Posts: 4,991
    edited April 2025
    If you installed any values other than those above, I'd say yes. Unless it is a trick question
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • lms
    lms Posts: 54
    Not a trick, I got caught up and didn't do my homework. Assumed all crs's had 16mh inductors. No wonder it sounded, off. Fark. Oh well, out they come, hooking the old ones back up for now. If anyone in the future posts that they are looking for 16mh, have them message me.
    VR3 Posts: 29,763
    Just unwind it to the right value
  • lms
    lms Posts: 54
    I have no idea how to do that right.
  • ken brydson
    ken brydson Posts: 9,108
    lms wrote: »
    220, 221 whatever it takes...
    edited April 2025
    lms wrote: »
    You need the proper meter to get to the proper value.
    Do you know the proper inductor value for yours? Am I overlooking it above?
    I'm thinking with the inductor values listed a laminated would not be beneficial.
  • lms
    lms Posts: 54
    5.6mh.
