Polk crs+ Erse Super Q Inductor question
    pitdogg2 Posts: 27,883
    edited April 2025
    lms wrote: »
    I have no idea how to do that right.
    You need the proper meter to get to the proper value.
    Do you know the proper inductor value for yours? Am I overlooking it above?
    I'm thinking with the inductor values listed a laminated would not be beneficial.
  • lms
    lms Posts: 54
    5.6mh.
    lms wrote: »
    5.6mh.
    That is a lot of unwinding from 16mh.
    VR3 Posts: 29,731
    If you play your cards right you could make baby inductors along the way
    Toolfan66 Posts: 18,412
    At this point, is where Larry would just mod them to CRS+’s
    Get the two needed drivers, point to point crossovers, RD-0198 tweeters. Etc.. 🤪
  • Gardenstater
    Gardenstater Posts: 4,921
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • lms
    lms Posts: 54
    Yep, found the uscoils last week, ordered them this morning. From what I read, erse employees started uscoils, so they are pretty much the same coils. Not expensive either. On order.
  • lms
    lms Posts: 54
    Life got in the way, just mounted the 130's, but before I fire these up, will the way I have them wired work? I know these need to be in Parrell, but looking at how I wired I'm wondering if this is in series?
    VR3 Posts: 29,731
    edited June 2025
    The cap goes from the dimensional driver negative to sda connector. Keep in mind on this series the connection for the sda cable on each speaker is different. This is important as if it's not it's a short
    The inductor is connected to the dimensional driver negative and the stereo driver negative
    Caps in series decrease, caps in parallel increase
  • lms
    lms Posts: 54
    I rechecked the wiring, left PR out and played music, bingo, they work, dimensional is working based on changing balance. Before I button them up and based on how I soldered the two caps together, does this look correct? I'm pretty sure it is unless you have to have both leads on each side connect to the spade??
    VR3 Posts: 29,731
    I honestly can't make heads or tails of your photo lol
  • lms
    lms Posts: 54
    lol, yeah, it's fricken cramped in there. Basically, I'm just over thinking this is all. I was just wondering if the caps were soldered the right way and not in series, but there is no way these are in series the way I have them. Thats what happens when you wake up at 3:30
    VR3 Posts: 29,731
    Series would be like Christmas lights
    Parallel is like a big hug
