Sda srs first gen crossover build
VR3
VR3 Posts: 29,731
Fun build wrapping up
Tweeter network
Clarity cmr
Clarity csa
Path audio
Jantzen inductors
Mid/sda network
Clarity csjantzen inductors and c coil
Supra rondo wiring
Aluminum termal plates
9 awg sda cable nl4 connectors
Point to point
    pitdogg2 Posts: 27,883
    Fantastic!
    xschop Posts: 5,796
    More eye candy.
    VR3 Posts: 29,731
    Thank you 😁
    xschop Posts: 5,796
    Did you add that sheathing to the IC cable? That's slick.
    VR3 Posts: 29,731
    Yes sir, it's a carbon fiber tech flex, looks pretty nifty in person.
    How does it cut ? Fray easily ? I like!
    VR3 Posts: 29,731
    I use scissors and a lighter, is not actually carbon fiber but looks like it.
    Seems durable! I think I purchased from parts express, I'll have to find a link
    Roger on that. I knew at one time I bought some that frayed really badly. The next time I bought some I spent a little more and it cut clean and didn't want to come apart as easily as the cheaper stuff I had bought. A little adhesive shrink tubing and it worked very well. The cheaper stuff if you got a heat gun close to it, it just melted before the shrink tubing shrunk and it would start fraying at the edge of the shrink tubing. I discarded the rest of it I had.
    Clipdat Posts: 13,104
    Exemplary work as usual.
    VR3 Posts: 29,731
    Yeah you have to burn the ends or it just comes apart
    Thanks guys!
    F1nut Posts: 52,381
    edited July 2022
    I used to heat up an old sharp knife to cut the Tech Flex, worked perfectly. I now use a rope cutting hot knife. It's a blade device attached to a heavy duty soldering gun. Same result, just easier.
    Edit: this is a good source for Tech Flex and a bunch of other stuff.
    https://www.wirecare.com/
  • Faustin
    Faustin Posts: 1,151
    Them pictures got me breathing heavy! Sweet!
    VR3 Posts: 29,731
    Thank you!
  • polk_salad
    looks great AND expensive. what's the cost of all this excluding the interconnect? do you have a parts list? i'm considering the orig SRS recap and likely this grade of caps.
    SCompRacer Posts: 9,385
    Nice work! Highest marks!!!
    VR3 Posts: 29,731
    Install looking good!
    Thank you guys for the kind words!
    xschop Posts: 5,796
    Very nice handiwork (again). Is that factory crossbracing? I've never seen pics of that type before.
    VR3 Posts: 29,731
    First gen srs has that brace
    Thank you!
  • gregmoyers
    Awesome. Best gen one crossover mod I’ve seen. Beautiful. I will most likely be in touch.
    VR3 Posts: 29,731
    Thank you!
  • gregmoyers
    Where did you mount the C Coils?
    Can you post pic of them? Im getting ready to install mine. Same cabinet.
    VR3 Posts: 29,731
    You want to put it as far away from anything steel and the other components as possible
  • gregmoyers
    Gotcha
    On side maybe?
    VR3 Posts: 29,731
    Yeah the upper compartment in between us should work
    VR3 Posts: 29,731
    edited April 2025
    A slightly different take!
    Forgot the sda inductors in the photo!
  • skipshot12
    skipshot12 Posts: 2,142
    Man I’d love to have those in my blade/blade gen 3’s.
    Must sell my vr4….
