Sda srs first gen crossover build
VR3
Fun build wrapping up
Tweeter network
Clarity cmr
Clarity csa
Path audio
Jantzen inductors
Mid/sda network
Clarity csjantzen inductors and c coil
Supra rondo wiring
Aluminum termal plates
9 awg sda cable nl4 connectors
Point to point
Tweeter network
Clarity cmr
Clarity csa
Path audio
Jantzen inductors
Mid/sda network
Supra rondo wiring
Point to point
Fantastic!
Thank you 😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Did you add that sheathing to the IC cable? That's slick.
Don't take experimental gene therapies from known eugenicists. -
Yes sir, it's a carbon fiber tech flex, looks pretty nifty in person.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
How does it cut ? Fray easily ? I like!
I use scissors and a lighter, is not actually carbon fiber but looks like it.
Seems durable! I think I purchased from parts express, I'll have to find a link- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Roger on that. I knew at one time I bought some that frayed really badly. The next time I bought some I spent a little more and it cut clean and didn't want to come apart as easily as the cheaper stuff I had bought. A little adhesive shrink tubing and it worked very well. The cheaper stuff if you got a heat gun close to it, it just melted before the shrink tubing shrunk and it would start fraying at the edge of the shrink tubing. I discarded the rest of it I had.
Exemplary work as usual.
Yeah you have to burn the ends or it just comes apart
Thanks guys!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I used to heat up an old sharp knife to cut the Tech Flex, worked perfectly. I now use a rope cutting hot knife. It's a blade device attached to a heavy duty soldering gun. Same result, just easier.
Edit: this is a good source for Tech Flex and a bunch of other stuff.
https://www.wirecare.com/ -
Them pictures got me breathing heavy! Sweet!
Thank you!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
looks great AND expensive. what's the cost of all this excluding the interconnect? do you have a parts list? i'm considering the orig SRS recap and likely this grade of caps.
Nice work! Highest marks!!!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Install looking good!
Thank you guys for the kind words!
Very nice handiwork (again). Is that factory crossbracing? I've never seen pics of that type before.Don't take experimental gene therapies from known eugenicists.
First gen srs has that brace
Thank you!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Awesome. Best gen one crossover mod I’ve seen. Beautiful. I will most likely be in touch.
Where did you mount the C Coils?
Can you post pic of them? Im getting ready to install mine. Same cabinet. -
You want to put it as far away from anything steel and the other components as possible- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Gotcha
On side maybe? -
Yeah the upper compartment in between us should work- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
A slightly different take!
Forgot the sda inductors in the photo!
Man I’d love to have those in my blade/blade gen 3’s.
Must sell my vr4….
