Snub Way road test
2456
  • muncybob
    muncybob Posts: 3,225
    Check out the link at the top of this thread.
    Yep, my name really is Bob.
    F1nut Posts: 51,655
    It's a bot
  • jdjohn
    jdjohn Posts: 3,315
    edited March 28
  • muncybob
    Lesson learned, that's the last time I reply to anybody w/o 100+ posts :(
  • muncybob
    Snub is on the Way
    PM sent, to Jody...please PM me when you are ready to send it on for the next person's info.
    Since Tom's thread kind of started this and since there are some "reviews" already in that thread, maybe we post any findings there so they are all in one place?
  • simm
    simm Posts: 593
    If not too late I’d like to be added to the list. My components are plugged directly into the wall or a surge protector with no other treatments or noise reduction device so should be interesting to see if this makes a difference. I’ll send a PM with my info.
  • muncybob
    Not too late
  • Upstatemax
    Upstatemax Posts: 2,728
    I want to jump in on this as well.
    PM coming.
  • muncybob
    No problem...after a bit of a slow start we now have 9 "testers".
    treitz3 Posts: 19,942
    Honestly, I wouldn't mind being on it as well. I know I already have one, but it would ease my curiosity if these are a cumulative thing. I don't think they are, but it wouldn't hurt to try.
    My only request is this....since I already have one (along with the MC), place me at the bottom of the list. Let others see (or rather, hear) for themselves what it does.
  • muncybob
    Certainly cannot deny entry into this universe to the man that started it all!
  • pearsall001
    pearsall001 Posts: 5,218
    muncybob wrote: »
    I'm still surprised that only 9 forum members are intrigued enough to give the SnubWay a try in there system. Nothing to lose but some spare change to send it off to the next in line.
    Agreed. For the potential of what is has to offer a system's performance? This is a no brainer. Maybe folks just need more positive reviews....or because it's a "tweak", they automatically discount it - which is a major mistake in my book.
    Even if folks like it, it's not like they will be out close to 2K, like the SRA demo program. This unit is only $300. With around $10 to test (just to see what happens)?
    I don't get it. Most of the people are on this forum to see how they can improve their system, ask for help or talk about the latest and greatest. Well, this is definitely one of those things!
    Tony M Posts: 11,566
    I would've loved to hear if they reduced the noise in either of my many systems, but I'm sure there is a consensus that I wouldn't be able to tell the difference because of my tinnitus. :D
    I will be reading all the reviews, for sure. :)
  • muncybob
    Tony, I can tell you after only 2 hours on a "bad tinnitus day" (on those days I normally don;t even bother to fire up the rig) that I can hear a difference. With that said, I'm hoping it's like others have mentioned and after a few more days I'll be smiling. Still optimistically skeptical though.
  • WagnerRC
    WagnerRC Posts: 2,199
    Put me on the list please. I have to give it a shot. Thanks
  • invalid
    invalid Posts: 1,439
    Do you have to use a power strip with this unit?
    edited March 31
    No sir. Any standard outlet will work. Even if it is on a power strip or other device, but those are not required at all.
  • PSOVLSK
    PSOVLSK Posts: 5,371
    muncybob wrote: »
    I know it’s only been a couple of hours, but am I reading it correctly that you’re hearing a
    degradation in sound quality?
  • muncybob
    Not at all. Others have mentioned that the first few days there is not much of a difference but then...wham. I'm waiting for the wham factor.
  • PSOVLSK
    muncybob wrote: »
    Good deal! Glad I read it wrong.
    On another note, I wonder if you could use something like this if the number of outlets available is a problem.
  • jdjohn
    jdjohn Posts: 3,315
    I have the SnubWay demo unit in-house now B) I'm confirming with Bob that this is a brand-new unit, with no break-in on it yet.
    Another question: is it safe to 'hot-swap' this in-and-out of sockets? In other words: do the electronics need to be powered off before placing the SnubWay in or out of the circuit?
  • smglbrth
    smglbrth Posts: 1,495
    edited April 1
    PSOVLSK wrote: »
    muncybob wrote: »
    This is a cool idea and might make the most difference, in the case of the APC I have. No amp rating though...
    That would be rated at 15 amp (you can tell by the plug style).
    I have swapped them hot before. IIRC, the worst I got was about slight pop one time while the system was playing. Why only one time, I couldn't even begin to explain to you, and I don't remember if that was from one of the Puron's, from the Snubway or the MC. That was a while ago.
  • jdjohn
    jdjohn Posts: 3,315
    I'll hit the mute button first.
  • bcwsrt
    bcwsrt Posts: 2,361
    If I recall correctly, their website says have at it. I’ve done it with no ill effects.
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
  • Polkitup2
    Polkitup2 Posts: 1,640
    Zero issues here hot swapping and I have done it many times.
  • jdjohn
    jdjohn Posts: 3,315
    Thanks for the replies about 'hot-swapping'. In my initial testing, I've also had no issues with that thus far.
    My next question is: has anyone done testing that is isolated to source components? I want to test via headphones about potential enhancements with source components, versus full-system enhancements with a power amp and loud-speakers.
    You may be on your own with that one...
  • jdjohn
    jdjohn Posts: 3,315
    Tom, I hope you see the conundrum here. A gadget that potentially enhances the playback of 'power' components, versus 'source' components...has limitations.
