Veri Fi SnubWay......don't listen to music, experience it!
    treitz3 Posts: 20,367
    One idea presented elsewhere would be to go to HD and get a 20amp 3 way splitter. It isn't ideal but it would allow you to place the original equipment into the same outlet, along with both the Snubway and MC. If it doesn't work out, you could always return it. A Ridgid 3 plug, heavy duty 2' extension cord only costs $23, and might also allow to to do more experimenting to see what works best for you. Just food for thought.
    Alternatively, if your outlets are in series, you could possibly place them in the outlet before your system.
    One other thing I would like to mention is this. The impact from each unit (at least on my rig) were equal.....maybe with a slight nod to the MC (but that may have been because of the cumulative effect, I never took out the Snubway just to test the MC). With both of them? I am STILL in awe at what I am hearing. Not, "pretty much" everytime I listen. It's literally everytime I listen. Whether the rig is cold, or if it has been running non-stop for days on end. FWIW.
  • haudevbe
    haudevbe Posts: 17
    That sounds like an incredible experience! Whatever device or tweak you’ve added to your system clearly made a profound impact. Care to share what it is? Given your reaction, I’m guessing it’s something that significantly reduces noise, enhances detail retrieval, or improves the overall musicality of your setup.
    Is it a power conditioner, a DAC upgrade, a reclocker, or some kind of isolation tweak? I’m curious because I’ve seen a few game-changing products in this price range that can elevate an audio system far beyond expectations.
    F1nut Posts: 52,406
    Yep and been reported. The same user name and type of posts are all over the Net.
  • Polkitup2
    Polkitup2 Posts: 1,644
    I have had the Snubway and Main Stream plugged in my system for about 8 days now - Initially, I was not blown away by what I was hearing. I did notice some improvement in clarity and reduction in noise floor, but it kind of left me feeling underwhelmed.
    Fast forward to three days later and when I sat down to listen I was like "Wow". Something had changed for the better - by a lot. I was now hearing much more clarity and the reduced noise floor allowed me to hear more low level detail in recordings. I noticed for the first time room ambience in some jazz recordings that I had not picked up on before and the music overall seemed to reach out and pull me in more than it had previously.
    I tried various positions for the devices and for now have settled on the Snubway being in the duplex outlet that my power conditioner is plugged into and having the Main Stream plugged into the first outlet on my power conditioner. This configuration was recommended by Vera-fi and seemed to work best for me. When I removed either one of the devices the result was less than when using both.
    Mark from Vera-Fi was very helpful with any questions I had. Highly recommended to try. Thanks Tom for recommending these devices!
  • maxward
    maxward Posts: 1,744
    My experience pretty much mirrors that of @Polkitup2 . It took a few days to realize the full effect. I was a bit hesitant to plug my integrated amp into anything other than the wall. So I tried it into the power conditioner for a few days before the Snubway and Main Stream arrived and heard no difference. This allowed me to use them as Mark recommended. After about two weeks I swapped them. I just swapped them back and am convinced that this is the best configuration so far. I suppose I could try more combinations, but at this point I’m not sure I’ll bother. I recommend that if you’re on the fence, take advantage of the trial being offered.
  • muncybob
    muncybob Posts: 3,355
    I put this in the road test thread, should have been put here.
    So, while I've had the SW for almost 2 weeks, I did not have a lot of time to spend with it until the last few days. As previously stated, I was not expecting much from my modest rig and esp from my ears.
    I was pleasantly surprised though. Initially I would be listening carefully for "differences", maybe too carefully. Then just a few nights ago I settled in to some very familiar tunes and took off my critical hat and just enjoyed the music. After a bit I noticed that my feet were tapping and head somewhat bobbing more than usual, then it occurred to me I was actually enjoying the tunes more than usual. This revelation brought a smile to my face and then the critical listening hat was put back on, why the change?
    I must say I wasn't hearing much of anything I had not heard before, but what I was hearing was clearer. When centered on good recordings, vocals sound like the artist was right in front of me. Same also with keyboards. After realizing this I actually got a bit excited which lead me to listen to more music than usual.
    By this time the Mrs was off to bed and the system had to be turned down a bit to avoid nasty comments from upstairs. The L600s along with the sub really shine in the bass department, esp with a bit of volume. Previously I would miss the bass a bit at the reduced volume, but not this time.
    I can't say that the SW can improve a poor recording though, actually just the opposite. But to my ears, a well recorded album sounds really good. I wish I had a more revealing system because I still have that "can it get better" itch :wink:
    Yep, my name really is Bob.
    Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub.
  • jdjohn
    jdjohn Posts: 3,462
    My time with the SnubWay in the demo 'road test' program is done, so now it's time for me to relay my experience. The demo unit had no previous break-in time (from what Bob discerned), so I waited a few days before doing any serious, critical listening. As far as placement, I plugged the SnubWay into the second socket in my main rig's duplex outlet. The outlet is a PS Audio job (can't remember the model #), but it has a very firm grip.
    For background, the other socket in my PS Audio outlet has a Puritan PSM156 power conditioner plugged into it. So, one socket had the PSM156 plugged into it (with all of my separate components), and the other socket had the SnubWay plugged into it. I found this configuration to yield the best results.
    After allowing a few days of burn-in for the SnubWay, I started doing some A/B, critical listening. I will go ahead and state that the differences I heard were somewhat subtle, and not night-and-day differences. I personally think (in my system) that the filtering capabilities of the Puritan PSM156 power conditioner did most of the heavy-lifting, and what the SnubWay did was incremental, BUT still recognizable.
    The most basic adjective I can convey with the SnubWay is more 'loudness'. With the SnubWay in-place, it seemed that the volume output was 0.5-1.0 dB louder. That is not really possible with a passive device in-circuit, so I have to assume that it is a lower noise floor (due to filtering), equating to a louder perceived volume in musical content. This also equated to a bit more separation and isolation in instruments.
    I also perceived a slightly wider and deeper soundstage with the SnubWay in-place. With the SnubWay, the wall of sound from my loudspeakers expanded a bit, both in 2D and 3D. I did several listening tests with the SnubWay in-place, and then with the SnubWay unplugged. The results were consistent.
    So, is it worth it? From what I have read, the Main Stream/Master Class seems to have a more pronounced impact. Is the SnubWay minor league, and the MC major league?
  • muncybob
    Sounds like your experience was very similar to mine. Clearer and different in a good way.
    heiney9 Posts: 25,724
    jdjohn wrote: »
    I am due at some point to demo this. My Puritan conditioner has made such a huge difference I am not sure this will even register. So, it's good to hear your comments and I'll try it the same way to see if I can hear a difference.
  • PSOVLSK
    PSOVLSK Posts: 5,452
    jdjohn wrote: »
    My understanding is that they are equal but handle different frequencies, so they are meant to be used in tandem.
    Clipdat Posts: 13,107
    This StubNose stuff is all fine and dandy, but what if I like noise and want to add more back in to my system? Is there a product that does that besides tube amps? LMK!
  • muncybob
    I never gave a thought about "noise" in my system. I think I need an education of just what you can expect to hear in a noisy circuit and how did it get there in the first place....motor running(fridge,freezer in the home)....other environments that are getting there power from the same source/line?
    I'm wondering if I did not have a WOW experience because we don't have a lot of this noise to begin with? We are in a rural setting with very few homes within a square mile of us, does that make a difference? It would obviously make a lot of sense if there isn't a lot of noise to begin with that nothing in the circuit should make a big improvement, right?
    We do not have any noise filtering in our system other than what perhaps may exist in the Panamax outlet/surge box.
    @Clipdat Said respectfully, can you try to be a gentleman, instead of a smart aleck when joining in on the conversation? It's called a Snubway. Every post you have made on this thread, and the other one, rings with the same tone. It's getting rather old and doesn't further anyone's knowledge, or the conversation. It just adds unnecessary noise to the conversation.
    So, let me clarify a bit on the noise I am talking about. It's a combination of noise floor, room minimum dB level, RFI, EMI and Schuman resonance, Eddy currents, phase noise and/or jitter, ground noise, common mode noise, leakage current, Allan deviation, reflections within the room or even the cables themself, timing variances within the 1's and 0's (whether it be immediate, misread, short or long), along with noise that rides the incoming A/C waveform, or if you stream? Through that incoming cable and upstream infrastructure noise. These are just some of the things that affect the sound and yes, it's audible when these types of noises are gone.
    This noises aforementioned are not the same as vinyl surface noise from a TT or tube noise, although you want to try and keep those as low as possible as well. What I am saying is that the noise I am referring too is not the same. Many people don't even know they have noise…..until it's gone.
    PSOVLSK wrote: »
    Correct. The Veri-Fi Main Stream - Master Class Dynamic Parallel AC Line Conditioner is focused on and targets the frequency range from 10kHz to 20kHz, but it's particularly potent in and around the critical 20kHz region, where hum, hiss, and hash tend to be most prominent. The SnubWay's greatest range of effectiveness is targeting the problematic 400kHz-600kHz range.
    I had made the comment that I would give the MC the nod as to the greater effectiveness, but this is on my system and I already had the Snubway in place for 1/2 a year, so that may very well just be chalked up to a cumulative effect. Every one has differing noise levels, so what works as "the best" for one person's system, may not reflect the situation in someone else's system. And vice-versa.
    When it comes to the Puritan, it is my understanding that every outlet is on a dedicated isolation transformer, which block electrical noise and interference by providing galvanic isolation. Either one of these devices (and this is only conjecture) would be rendered useless on a device like that. In Jody's case, he found that adding the Snubway into the outlet that feeds the Puritan yielded the best results for him. That makes sense, but when he still noticed a consistent difference after installing the Snubway, it just makes the argument that the Puritan removes much of, but not all of the noise.
    I have found this to be true, no matter the product used, or a companies "claim" that all noise is eliminated. I have yet to find any product that eliminates all of the noise. That said, the products that I have introduced into the rig have severely thwarted the audible noise and the end result is simply nothing less than spectacular - for what you actually hear (and more importantly, what you don't hear).
    muncybob wrote: »
    Sounds logical.
    muncybob wrote: »
    Oh, yeah!
    muncybob wrote: »
    I cannot argue that. It makes perfect sense (at least it does to me).
    muncybob wrote: »
    Now here is where we differ, and this may go to help explain the inquiry of your first question. I have many products utilized within my rig that directly attack noise from entering the system, both in the room and outside the room. Each product seems to attack different things. Some of these are very subtle in noise abatement, while others are flat out undeniable and absolutely wonderful in what they do and how they affect the system's performance.
    I'd like to point out that in no way am I an expert on noise. Heck, I just started discovering it when I noticed that my streaming rig started to sound much quieter than my Reference Marantz SA-7S1, with a separate DAC. One of the revelatory times was when I was at Trey's house years ago. It took me a while to remember where this post was made, but here I am talking about "noise". Not even on my system! It is very audible, as you are about to read...
    treitz3 wrote: »
    So, I was privately speaking with Trey about these "unwanted artifact(s)" and we started talking about what options he would have to do/what he could possibly do to change it. During this discussion, Trey looks down at his phone and jumps up like he just won the lottery or something. After a mad dash out the door, he comes back in with this little box. I'm thinkin', what's he so excited about?
    Apparently, he had ordered a 1.5 meter digital cable. Little to my knowledge, apparently the length of the cable is just as much, if not more important than the metallurgy or build quality because of feedback issues. Who knew? Well, apparently he did. So, we unbox and unwrap this cable, shut the system down and within 5 minutes, the system was back up and running, new digital cable installed.
    We didn't know what to expect but man, that cable made a pretty remarkable difference in Trey's rig. From top to bottom, the clarity, texture, detail, definition increased in spades (not a subtle difference) and it removed "unwanted artifacts" that were present in the midrange drivers, so you were able to hear things that were always there, but masked. Much more musical information was now easily heard and we both heard things that we did not hear just an hour or two before (or ever on his system).
    Everything I was relaying to Trey that was in need of attention got taken care of within 5 minutes. Now, everything is in crystal clear focus with great clarity, texture and definition. Up and down the spectrum of frequencies, there was a noticeable difference.....but that critical midrange issue? Gone. *Poof*. Like it was never there. Now I really wanted to stay!
    Now, I have since learned that what the cable swap out did, was reduce the reflections within the cable itself. I didn't know at the time that what I was describing was this "noise" that I am talking about here. 1 cable is all that changed that day. But it helped, very effectively might I add, to thwart what I used to describe back then as "unwanted artifacts". This very thing is part of what I am trying to point out as noise in a system.
    Oh, I'd also like to point this out. The cable that was replaced was the same exact cable as the one that was previously installed. The ONLY difference between the two was the length.
    Without the new cable even being broke in yet (compared to the cable that had been in his system for quite some time), the differences were immediately audible and when we first noticed what we did, neither of us were even sitting in the sweet spot, because the both of us were not really expecting to hear any change whatsoever.
    The look we both gave each other (*off axis) after about 20 seconds of a song we had just played an hour or so earlier was priceless. We both knew what we heard, and we both had the same observations but that look...
    That look summed up confusion, excitement, insightfulness, discovery and awe, to name but a few. It was very enlightening and pinpointed one of the exact noises I am referrring to here. FWIW.
  • muncybob
    "so you were able to hear things that were always there, but masked." Tom, thanks for the input and this is what I have experienced thus far with the SW.
    You've got me thinking about cable length now, as I know there are cables in my rig that are too long. I have a birthday coming up, hmmmmmmmm
    @treitz3 Ah, ok, so jokes aren't allowed in this thread? Understood.
    I'd give this product a try, but I told myself no more components from convicted felons in my system. Shrug.
    Your "jokes" are about as funny as a dirty joke being that a horse fell in the mud. What a damned kneeslapper. I thought I was gracious to you in my response, but alas, you being a gentleman about it is apparently too much to ask. All you did with your last post, is once again, add useless "noise" to the thread. *shakes head*
    If you don't want this product, that's all fine and dandy. No one here gives a flying (fill in the blank) But please let the folks who are offering up real information be allowed to read up without said additional useless noise. It adds nothing to the discussion.
    F1nut Posts: 52,406
    I'd say not giving money to a convicted felon is adding to the discussion.
    Oh, FF's sake. Jesus himself, along with our current leader were both convicted felons.
    More noise. I respectfully ask that while this is an apparent fact, that it not be spoken about moving forward, especially ad nauseum. Please go F up someone else's thread or start a new one, specifically about this. The folks who are reading this shouldn't have to sift through all the added noise.
  • muncybob
    I agree with Tom here. The backstory of the person in question was plainly stated earlier and that should be enough to develop each person's outlook. Nobody is trying to sway anybody's opinion about that. While I can't condone what happened with that person, I also thought why not try out the product. So I took all the risk by contacting him regarding the price and was surprised when he agreed to the"road test"...a few days later w/o any $$ exchanging hands I received 2 of the devices...one to share with anybody interested at no risk at all.
    I'm sure most, if not all, in the test has a rig that is much higher up the ladder than mine so I really wanted to see if this device made a difference in their equipment. I would have been surprised if it didn't in mine based on Tom's (and others) experience.
    I don't understand why anybody that has no intention at all in a product would muddy the waters for those that are interested. With that said, can we just have actual experiences with the SW here and let the bickering out of it?
    edited April 2025
    Think of the noise we are talking about in here as "unwanted artifacts" from any piece of passive or active device or cable in your rig. If you eliminate just one unwanted artifact it may not be audible, but it's definitely a cumulative effect of everything you do to your rig.
    The old adage definitely holds true "Everything Matters". This doesn't happen overnight. In my journey it's taken a long time. Meticulously paying close attention to eliminating "unwanted artifacts".
    This includes choice of gear. The XA25 is a superb example of a design that gives you about as naked a signal as you can get. New techniques, new Mosfets, and ridding the amp of degeneration (a form of negative feedback)
    Read my review here.
    https://forum.polkaudio.com/discussion/199380/finally-pulled-the-trigger#latest
  • jdjohn
    jdjohn Posts: 3,462
    Aren't we due for another SnubWay review at this point?
  • muncybob
    smglbrth had it but life got in the way and I don't think he had enough time to evaluate it. He may be getting it after the last person reviews it down the road for a 2nd shot.
    In the meantime daddyjt should be receiving it today and hopefully we'll hear from him later next week.
  • muncybob
    reported
    Master Class A/C line conditioner -
    Since I never really did a review of this thing, I thought I'd share a story with you about this device. Please be forewarned, this is a long post. Informative, but still long.
    So, about 3 weeks ago, I was out in the living room watching some TV, while the rig was warming up to play some late night listening tunes. Out of nowhere was a lightning strike that, based upon the sheer amount of light beaming through the LR blinds, had to have been awfully close. At the same exact time, one of the loudest cracks of thunder I have ever heard was simultanious with the strike.
    It looked to have been close and I thought I would have walked outside to see a tree exploded or part of my house on fire. All of these thoughts happened within a split second, but when the light from the strike subsided, I noticed that the power was out in the house.
    Within seconds, my son had ran out from the room thinking the same thing I did. He said it scared the living crap out of him and we both walked out onto the front porch to survey the damage. Nothing. No damage, no tree down, no fire, no scorched exterior outlets, nothing.
    When the excitement subsided, we walked back inside and told him that the power should be back on soon. He stated that the power was on in his room. What? So, I looked in the kitchen and the fridge light was on. Hmm, so I guess it popped a breaker. No worries.
    So I walk back to the panel and sure as chit, the front of the house outlet circuit was in the off position. No worries, so I turned it back on. It immediately popped off again. Crap. That meant something on that circuit had a short in it. It was late and the rig is on that circuit, so I called it a day and just went to bed. I figured that I would just deal with it in the AM (it was a Friday, so I was off the next day).
    So, first thing in the AM, I unplug everything on that circuit and flip the breaker to the on position. No short, so the circuit and all outlets were fine. So, now all I had to do was plug everything in, one by one and when it tripped the breaker again, I would know what it was that had a short. I plugged everything in within the LR. Then I moved to the office and plugged everything in. No issues, which was great but at the end of that circuit is where my rig resides. That ain't good. At all.
    So, I waited the rest of the day, not wanting to know the inevitable. It was something in the stereo room. Reluctantly, around 7 that night, I built up the courage to finally go back and see what was what. Hoping for the best, but preparing for the worst.
    One by one, I plugged everything in for the main components of the rig. Turned everything on and no tripped breaker. Thank the man above none of the most expensive to replace components were damaged. So, I plugged in and turned on the AQ Niagra power strip that supports everything on the streamer and network devices in the room. Still no issues. So, I went back out to the LR and office and started plugging in all of my noise reducing devices, then back to the stereo room to start plugging them in there.
    I plugged in all of the Puron's and as I plugged in the Master Class A/C line conditioner, the circuit was tripped. AH-HA! That was the component that fried (or at least one of them). I removed it from the outlet, turned the circuit back on and plugged the rest of the stuff in. No further issues and the rig was running fine (albeit, not sounding quite as good without the MC A/C line conditioner).
    Still, very thankful that it was just that, and not something else that would have put me without music for a while. I had been there before from another lightning strike at a different house...and it wasn't fun. At all.
    So, anyway....I got to wondering why it was just that unit that got fried. It was located on the first outlet on the in series outlets that fed the system. The only other thing that was plugged into that outlet was one of my Rythmik subs, which works perfectly fine. Curiosity got the best of me, so I called Mark up and to my surprise, he answered my call right off the bat (on a weekend morning to boot).
    I told him what had happened the night before and flat out asked him if it had sacrificed itself to save the rest of the system. He stated that there is a capacitor in the design that will do just that. So, this device not only is a great addition to the rig, it also saved it from untold damage. Very enlightening (no pun intended).
    The man was very accommodating. He will accept the return of the blown unit, and send me another one. He even sent me a return label for the damaged unit. I flat out told him that I would be happy to pay for another one, but he refused that offer more than once. That he was gonna make it right.
    It wasn't long afterwards that I ordered another one anyway, because I didn't ever want to go without one of these, ever again, plus I was kind of curious to see if more than one would improve upon anything. That remains to be seen, but anyway, these are my observations when the first one got delivered this past Wednesday afternoon.
    Continued...
    Immediately after install -
    Noticeably lower noise floor.
    Increased visceral impact of registers, especially in the lower regions.
    More separation and quiet in between the images.
    Greater sense of overall realism/palpability.
    Definitely an increased depth, and by a large margin. More layers of sound to the reproductive effort and very 3-D in all directions, which make the speakers and room on my system not part of the equation.
    Crystal clear sound with no leading edge and greater follow through with a natural rolloff.
    More palpable timbre to voices and instruments.
    Still some slight unwanted artifacts on certain frequencies on occasion. It's minor but noticeable to these ears. NOTE - these unwanted artifacts were gone after about 2 hours of being installed. It just dawned on me that I haven't heard it for a couple of songs now. NOTE 2 - After 6 more hours of continuous listening, these artifacts never returned.
    When I mentioned depth before, it is getting better. Listening to James Taylor's, "Light 'em up", the background singers range from 9 to 15 feet back from James, with a very clear blackness between the layers of singers.
    4 hours in, and this is just musical bliss. It's just so clear and fluid...like the music is dancing in front of you, around you, having an effortless and playful time doing so.
    I have been having a sheer blast listening to music as of late, and this is also in part to another addition I have made to the rig. That post/shootout is coming to a post near you. All I can say is that when I first put this device in? I knew within an hour and a half after install that I liked it well enough to post about it on this thread. I don't think I have ever offered an endorsement on any device for my rigs over the years within an hour and a half. It was that profound to these ears, and I thought I would actually share my observations the second time I installed the Master Class A/C line conditioner with all of you.
    Simply put, the Snubway and MC combo should be standard equipment for any rig. The enjoyment they bring to the reproductive effort table is probably the best value one would ever find in this hobby, even at quadruple retail.
    I am no longer just listening to the music, I am truly experiencing it.
  • muncybob
    Interesting read Tom. We have had several of those close lighting strikes in the last few years and upon suggestion from this site I had a whole house surge protection system installed. Any surge will hit it before the breaker panel. It has 3 replaceable breakers in it that will take the surge, fortunately have never had any issues (knocks on wood). Mark seems to be a good person these days.
