Can I fix a mark Levinson 33 Monoblock thread
24
    VR3 Posts: 29,457
    Well... changed out the 22uf electrolytics... 3 leaking, all way out of spec
    Amazing this bad boy even turned on to begin with >.<
  • skipshot12
    skipshot12 Posts: 2,019
    edited March 2025
    VR3 wrote: »
    Journey begins, first 2 caps changed. Originals 20% out of spec 400uf versus 330uf. New dublier cap measured 335, this should be fun... 😁
    You mean like this….
    Inside of my Krell Audio Video Standard before the can of air.
    SCompRacer Posts: 9,116
    VR3 wrote: »
    The anti-cappers will tell you the old cap standard was +80 or +100% and -20%.
    treitz3 Posts: 20,032
    Seriously? Wow. I'm glad we don't have to deal with them here.
    VR3 Posts: 29,457
    Two measured
    .002uf versus 22uf and we're leaking
    Another 5.6ud versus 22uf, also leaking
    The non leaking was 18uf
    In all fairness the replacement kaisai were 20.5 versus 22
    20% variance seems to be the norm for sure
    edited March 2025
    Variances are normal. Tolerance is another. Staying within said tolerance is paramount to the designer's original intention.
    billbillw Posts: 7,656
    In circuits that are not in the signal path, extra capacitance is rarely a problem. In those cases, the anti-cappers are right, as long as the opposite channel (if it is split) has a similar value.
    VR3 Posts: 29,457
    This is a 680p 100v ceramic cap... I'm thinking to include this in my capacitor swap as well, am I safe to assume any 680p 100v ceramic cap with h 85c to 105c operating temp is good?
    Is there a reason I shouldn't go to a film cap?
    F1nut Posts: 51,857
    I'd definitely replace it and with with same. Ceramic caps handle high heat better and that one is close to a heat sink.
    VR3 Posts: 29,457
    10 4!
    VR3 Posts: 29,457
    One fully recapped regulator board and I changed the two transistors that overheated.
    I checked continuity thru out the board and all the resistors.
    Fun fun fun!
    Now time to go to the next board
    VR3 Posts: 29,457
    How about this guy who was never soldered from the factory
    VR3 Posts: 29,457
    Alrighty.. I just ordered 236 parts (118 per board) for the next board! Fun fun!
    nooshinjohn Posts: 25,935
    VR3 wrote: »
    Covered by warranty?🤣🤣🤣🤣🤣😜
    VR3 Posts: 29,457
    Lol, hilarious the amp to my knowledge has never been serviced since it was built
    txcoastal1 Posts: 13,514
    If your board was like that, then likely all on that run and who knows how many more got missed.
    VR3 Posts: 29,457
    I mean there's so many parts it happens right?
    Honestly levinson spared no expense in the realistic sense. Very nice parts quality thru out, very impressed and the circuit boards while a pain to remove parts are very very nice to work with
    edited April 2025
    Nice find. Years ago I purchased a used InnerSound (CODA) Phono stage with a hum issue. They missed soldering the TT ground wire to PCB.
    VR3 Posts: 29,457
    Question for the hive mind - should I change relays while I am doing this? |
    Looks to be good quality made in japan NEC relays but they are also 30 years old
    edited April 2025
    Are they signal or output relays?
    I remove and ohm them out. Some are easy, plugged into a base, some were soldered in. I'll apply spec voltage to relay and ohm out the applied contacts. Some of the signal/head relays I've dealt with on tape decks were no longer available new.
    On some the plastic cover was easily removable. Some were sealed requiring cutting around base with exacto knife. Cleaned contacts with doubled up Kim wipe soaked with DeOxit. Followed up with 99% ISO. Sandpaper would remove silver plating. I've seen gold plated in some Teac tape decks.
    When my Krell amp was experiencing some crackling playing, the ex service manager with his own shop told me to bang on top rear of amp with my hand. It went away indicating dirty contacts on output relays. The ex service manager told me he had a massive load bank. He'd trip the amp into full output to clean them. I had to disassemble and clean.
    VR3 Posts: 29,457
    edited April 2025
    Interesting!
    I was able to locate the model relay from kemet versus NEC. There is alot of nos nec available as well
    Looking at the kemet datasheet they appear to be identical so I think I will swap them just for good measure.
    These relays are located on the input board which tie into the output boards.
    There's 4 total
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,276
    Tape recorders use lots of relays, every time a function is selected three or more relays have to click. The relays made by Omron are very well built.
    VR3 Posts: 29,457
    edited April 2025
    I had a bias trap relay on one of the three X-1000r's that had some residue in it. Some guys get carried away when spraying DeOxit on the mechanical ALPS switches on the bottom board. I don't have any removed pics. Sometimes I just want to get out of what I started and keep going.
    There was another narrow relay I had to clean as well.
    The Omron's in the Krell were still available. I left them soldered in place and just cleaned the contacts.
    VR3 Posts: 29,457
    Those are some nice looking relays! I love it.
    This has been a fun learning project.
    Here is what CHATGPT says about the relays in relation to the rest of the circuit -
    These relays are likely used for switching signal paths or power rails, potentially to:
    Select or isolate inputs/outputs depending on operating modes or protection logic.
    Switch power supply paths, like routing +PREREG or -PREREG to POS_REG / NEG_REG under certain conditions.
    Implement fault protection or startup sequences, using logic to control when parts of the circuit are energized.
    🔌 Control:
    The relays are likely being triggered by transistors or op-amps on the board, based on:
    Nearby drivers like MPSA14, TIP122, or MJE15033
    Associated fault detection or thermal feedback lines (e.g., FAULT, AMP_ON, THERMAL1/2)
    edited April 2025
    The Krell KSA 250 has a protection circuit. If it sniffed any DC on inputs it would trip. I learnt that with a DIY DAC where I omitted coupling caps on the balanced output.
    It was common mode DC between pos and ground, neg and ground.
    VR3 Posts: 29,457
    yes the Levinson has a multi relay start up sequence.
    I do believe changing the relays makes a lot of sense given that they have engaged every time the amp has started up over the last 30 years.
    Looks like NEC is KEMET now, so basically same brand/model etc.
    VR3 Posts: 29,457
    edited April 2025
    I've already changed a good bit of caps in this Pic.
    Still have about 20 or so caps and 30 or so resistors to change in addition to the relays
    edited April 2025
    Thats quite a hunk of PCB. Obviously your old can caps were just a single value. If you ever run into a project where you have multiple values in one can, Adapt a Cap is one solution. The value symbols are carried over into it. You have the option of jumpering the ground to mounting if the original was.
