Can I fix a mark Levinson 33 Monoblock thread
VR3
VR3 Posts: 29,752
So one of my monoblocks will not turn on... I have sourced over a hundred pages of schematics and service documents and I own a multi meter
Challenge accepted, long term journey
I suspect the regenerator which supplies clean power to the amplifier has malfunctioned. It is a lengthy process to remove said regenerator so I started at the top and will inspect as I go. First post involves the regulator board, I spotted two faulty transistors. Ordered all new caps and those two transistors for this board and the party begins!
«134
    VR3 Posts: 29,752
    Nooo doubt! I went to HD to pick up some compressed air and felt like I was buying uranium
    Viking64 Posts: 7,814
    WARNING: DO NOT ATTEMPT REPAIR UNLESS WEARING PINK CROWN!!!
    audioluvr Posts: 6,079
    I would leave it to the professionals. It's never "the transistor failed". There is always a daisy chain of failures brought on by one hidden random something or other caused by shipping damage.
    VR3 Posts: 29,752
    This is just the start of my troubleshooting, I am just taking it one board at a time.
    I am fully expecting to find many more issues and parts plus I'm changing every capacitor
    VR3 Posts: 29,752
    edited March 2025
    I've already sourced the big ones. I found a guy who ordered the super expensive dubliers for the larger board value and then I have chemi con for the cans. I ordered audio note kaisai for the electrolytic and new wima comparable for this board
    VR3 Posts: 29,752
    edited March 2025
    There are numerous threads on diyaudio of several guys who rebuilt them... Invaluable so far truly. One of the members sold me the hundreds of pages of info he had for 50 bucks... From all service bulletins to assembly and disassembly instructions etc. Literally everything Harmon ha so these amps. Blown away when I received it as I thought it was just schematics.
    Will see how it goes, it will be a learning experience and given the modular nature of the amplifier I could ship a piece to a tech if I felt I was missing something.
    billbillw Posts: 8,288
    edited March 2025
    That was a small miracle to get the service info for those amps. The few times I looked at getting Levinson schematics or bulletins, it was like hitting a brick wall. Their circuits are not easy to follow. Good luck!
    Hopefully you still have backup(s) to power the system in the meantime. I remember the feeling I had when my LSA was out of commission. Not fun.
    VR3 Posts: 29,752
    No joke, pure gold. It even has a dozen page document of every part number in the amp and their location, it's amazing
    I honestly don't get to listen much lately between being a dad, husband, work etc
    I have a secondary office rig that sees way more use
    F1nut Posts: 52,406
    Go for it Trey.
    FYI, you can order canned air from Office Depot. It's the best on the market. I buy it by the case.
    VR3 Posts: 29,752
    Interesting, is it cheaper than a left kidney and a shake down?
    F1nut Posts: 52,406
    edited March 2025
    VR3 wrote: »
    I think so, although the price seems to have gone up slightly since the last case I bought.
    https://www.officedepot.com/a/products/337994/Office-Depot-Brand-Cleaning-Duster-10/
    Ha, cheaper here.
    https://www.officesupply.com/technology/computer-accessories/cleaning-maintenance/air-dusters/cleaning-duster-pack-cans/p785312.html
    F1nut Posts: 52,406
    Skin tags too.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,387
    One approach would be to disconnect the power supply from the rest of the circuit. Then connect each section and see which connection causes the unit to not turn on.
    txcoastal1 Posts: 13,520
    VR3 Posts: 29,752
    Tom had sent me a link to one for 60, I ordered that and will see how it works and return the uranium.... Error.... Compressed can of air
  • skipshot12
    skipshot12 Posts: 2,156
    That Levinson mono block has a regenerator?
    I had to buy a ps audio regen….
  • invalid
    invalid Posts: 1,559
    Does this particular mark Levinson amp have any ribbon cables? Sometimes this can be an issue to look at also.
    VR3 Posts: 29,752
    It does have multiple ribbon cables.
    There are signs of smoke from the regenerator, which essentially supplies power to the whole amplifier. You have to completely disassemble the amplifier to arrive to the regenerator unfortunately.
    Given my limited schedule and my desire to have the amps completely rebuilt previously, I took this as a sign it was time to rebuild!
    VR3 Posts: 29,752
    You can see the black residue on the back of the faceplate, which is in front of the regenerator
    VR3 Posts: 29,752
    Journey begins, first 2 caps changed. Originals 20% out of spec 400uf versus 330uf. New dublier cap measured 335, this should be fun... 😁
    VR3 Posts: 29,752
    I am, the air gun should be here tomorrow
    treitz3 Posts: 20,360
    invalid wrote: »
    From the ribbons or the pins?
    edited March 2025
    treitz3 wrote: »
    invalid wrote: »
    Any pin/socket connection should be cleaned and re-seating as part of troubleshooting. I wouldn't suspect the ribbon itself unless it showed cracking.
    VR3 Posts: 29,752
    Given the visual signs, I am pretty confident it is not a ribbon cable. Especially already finding the burnt transistors on the regulator board. I do plan to deoxit any ribbon/mechanical connections.
    There are also some known things to do with these like replacing the surge resistors and replacing relays associated with the shut off/on sequences.
    In my research and experience so far, the issue with levinson ribbons is that the connections do not actually lock, they are simply seated and easily removed/connected.
