1…9192949697…260
    Tony M Posts: 12,001
    edited March 2025
    Enjoy those Bennic caps...lol
    I will...LOL. B)
    With my old ears, the speakers sounded awesome.
    billbillw Posts: 8,195
    edited March 2025
    Tony, all these years of hoarding....accumulating stuff, you haven't gotten hold of a simple 2-wheel hand truck (aka dolly) to roll speakers in and out of the shed? Shoot, that's one thing I will never lend out for fear of not getting it back.
  • skipshot12
    skipshot12 Posts: 2,141
    Are those rubber surrounds on the B&W’s?
    edited March 2025
    I have had a dolly for 35 years. I got a second one from a co-worker 20 years ago. I still have them both.
    I was concerned either of my 2 dollies would scratch the finish in some weird way ( no matter how I wrapped them, so I thought, I carried 80 lb Triton Ones with good control in 2015, so why not try these? I've been working hard and building my strength back for a year now.
    I knew these speakers were piano-finish and they had a huge base plate attached at the sellers' house. My wife pushed me to take her rolling cart with an upright handle with me this morning.
    There was one step that was short but the second was high. I thought "no" on the cart because of the second step. I just carried them out, put them on the ground, and then laid them over on thick knee pads to take the bases off.
    I had fairly good rest breaks between carrying each speaker and the receiver. ;)
    I now know in the future, I will not repeat what I did today. My legs are 1/2 what they were a year ago. I feel my back will probably fail if stressed hard in the future after today's test.
    skipshot12 wrote: »
    yes. Rubber.
    This is v2 but still...
    https://youtu.be/rYZ_84naayg
    pitdogg2 Posts: 27,882
    Tony, put those water pipe insulation tubes on the dolly with zip ties. Make sure the locking part is in back and you're good to go. If you're worried about the foot scratching the bottom of something break down a cardboard box slide it over the foot and tape it on.
  • Willow
    Willow Posts: 11,360
    @Tony M enjoy your new speakers. Jesse sleeps in a coffin you in a bed. To each their own. As long as you enjoy them
  • skipshot12
    edited March 2025
    Tony M wrote: »
    skipshot12 wrote: »
    yes. Rubber.
    They sound wonderful, the detail is top notch.
    I got a great surprise yesterday regarding my Infinity Prelude MTS speakers.
    I may have found a person that can repair the 850w B.A.S.H. Amps in the MTS’s subwoofers.
    Those B&W’s sound like they have the detail of the Prelude MTS. I do miss that type of brighter sound/detail, especially in the better recordings and higher-rez formats.
    It’s the reason I removed the poly switches, in my SDA SRS’, and just used a jumper.
    Tried different resistor values but preferred the sound with a jumper.
    Well, it won’t hurt a green damnit trying as they’re not able to be used the way they are.
    I’m sure glad I didn’t throw them out like I was tempted to do, I just couldn’t bare to make that commitment.
    nooshinjohn Posts: 26,138
    Does placing a receiver on its side improve the sound?
    F1nut Posts: 52,381
    No, it shifts the sound to the right side.
  • skipshot12
    Tony, as far as scratching the speakers when moving, I can relate.
    I ended up borrowing a dolly from a friend.
    I put the grills on my larger speakers then wrapped them with moving blankets. The blankets were held in place with electrical tape.
    To fully wrap them, including the bottoms, I first laid the blankets on the ground then laid the speakers down on their backs on top the blanket. Wrapped & taped then stood them back up and onto the dolly. Worked great.
    Now piano black…… I’d be very cautious with those rough moving blankets. Maybe a Saran Wrap type of layer first may do the trick before wrapping with blankets?
  • bcwsrt
    bcwsrt Posts: 2,676
    edited March 2025
    I dropped my vehicle off for PPF and front window tint today and got to see this machine that they just completed PPF, tint and ceramic coating on. Ferrari 812 GTS. Could’ve spent the rest of the day looking at it. Amazing!
    Brian
  • daddyjt
    daddyjt Posts: 3,246
    What’s “PPF”?
    ― Aleksandr Solzhenitsyn
  • bcwsrt
    bcwsrt Posts: 2,676
    Paint Protection Film.
    Brian
  • bcwsrt
    bcwsrt Posts: 2,676
    Or, in the words of @agingboomer, do your own research. 😂
    Brian
  • skipshot12
    edited March 2025
    What a lot of the more expensive vehicle folks do is PPF the whole car.
    That’s the film they put on the front end of the car to protect from bugs, rocks and the other things that f-up your paint, it’s that clear stuff they used to call a clear bra.
  • maxward
    maxward Posts: 1,742
    I wonder if the ceramic coating is needed if the whole car has the PPF.
  • skipshot12
    I can say without a doubt yes.
    The ceramic coating doesn’t prevent rock chips.
  • bcwsrt
    bcwsrt Posts: 2,676
    edited March 2025
    This particular place puts ceramic coating over the PPF. I’ve been using a retail (Adam’s) ceramic coating for the past several years. It does make the washing and overall maintenance process easier. PPF keeps the random rock chips at bay, though.
    Brian
  • skipshot12
    ^ 100% agreement.
    Adam’s is the ****. 3 of our cars done with Adam’s ceramic coating.
    The 89 soup has ceramic coating over the clear bra up front.
    Awesome stuff.
    mhardy6647 Posts: 35,554
  • aprazer402
    aprazer402 Posts: 3,463
  • OleBoot
    OleBoot Posts: 3,138
  • OleBoot
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,101
    bcwsrt wrote: »
    First time I have seen that Ferrari.
    The "flow" of that car from front fender to upper rear is perfect and magnificent!
    Harry / Marietta GA
    from hifihaven.org
  • ken brydson
    ken brydson Posts: 9,099
  • Geoff4rfc
    Geoff4rfc Posts: 3,047
    Tony M wrote: »
    Little road trip this morning. ;)B)
    Pioneer SC75 receiver and these HEAVY as lead gems. B&W CM10's.
    I always liked the CM series, nice score!!
  • OleBoot
