Can a 24V, 3 A , work for power
24V, 3A power supply work
Answers
    billbillw Posts: 8,173
    Need a lot more detail of what you are asking. Work for what?
    Usually the device will list the voltage and amperage requirements. If your device says 24V and less than 3A, it will work. If voltage is different, then you should find the correct voltage supply. If amperage needed is more than 3A, that also won't work, at least not for very long.
    VR3 Posts: 29,721
    I'm feeling lucky
    Yes, the answer is yes
  • OleBoot
    OleBoot Posts: 3,138
    edited March 2025
    VR3 wrote: »
    I'm feeling lucky
    Good for you for ending his Tesla range anxiety.
  • skipshot12
    skipshot12 Posts: 2,139
    Bahahaaaaaaa….
    Absolutely it’ll work.
    Just make sure you buy the most cheapest wan ewe cant feind.
