Can a 24V, 3 A , work for power
edmundghughes
24V, 3A power supply work
Answers
Need a lot more detail of what you are asking. Work for what?
Usually the device will list the voltage and amperage requirements. If your device says 24V and less than 3A, it will work. If voltage is different, then you should find the correct voltage supply. If amperage needed is more than 3A, that also won't work, at least not for very long.
I'm feeling lucky
Yes, the answer is yes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'm feeling lucky
Good for you for ending his Tesla range anxiety. -
Bahahaaaaaaa….
Absolutely it’ll work.
Just make sure you buy the most cheapest wan ewe cant feind.
