Speaker Gaskets - The best to use in 2025
Hi Guys,
I did some searching and alot comes up about gaskets, paper, Mortite, use of weatherstripping, various posts of people using other things.
Didnt seem to be a clear winner.
I have two pair of my 1988 built Monitor 11Ts apart to get the crossovers to Trey and I'd like to put in all fresh gaskets when I put them back together.
(I also just ordered hurricane nuts and bolts for them).
Personally my gut says I think I'd like to just put in all new factory gaskets if they are available, they did an amazing job for 37 years from 1988 until now.
What say you is the best option "Now".
Jimmy P
    F1nut Posts: 52,008
    edited March 2025
    The clear winner is the original gaskets. Unless they are torn/damaged do not replace. They are supposed to be paper thin.
    If one or more need replacement due to damage the gasket stuff at Parts Express is good enough. There are no factory gaskets available.
    Under no circumstance should you use Mortite.
    pitdogg2 Posts: 27,333
    edited March 2025
    Armaflex tape works as well. You will need to cut it to fit. Whether you use armaflex or the PE gasket stuff remember to cut on the diagonal were ends meet or you'll have an air leak.
    A soldering iron works good to burn screw hols where needed. IME just pushing the screw through material can cause it to grab the material and twist it up sometimes.
    nooshinjohn Posts: 26,002
    edited March 2025
    The compressibility of this material is on par with the original gasket material and has been teh preferred solution for more than a decade to replace the OE gaskets if needed. t1b9m1mhrdqp.jpg
    Toolfan66 Posts: 18,189
    Armaflex works great, my 2.3tl’s are the first build I did, and just used the original gaskets..
  • jimmypet
    jimmypet Posts: 46
    edited March 2025
    Thanks Guys.
    So my gut as a car guy was to replace all gaskets, but if you guys say if they are not torn leave it.
    I dont think any of mine were damaged on removal was I'll just put the stockers right back in.
    Very good intel on burning a hole vs just pushing the screw through if I had to make new gaskets.
    Thanks for the continuing education (and enabling LOL).
  • skipshot12
    skipshot12 Posts: 2,092
    ^ Was in the same way of thinking after acquiring my sda srs speakers, thought the gaskets should be replaced or upgraded.
    f1, in his subtle way, convinced me to stay with the thin originals.
    They seal up great, stay with them if not damaged.
