SDA 2 Interconnect Cable Need to Make One
    pitdogg2 Posts: 27,921
    Big to Big, Small to Small.
  • Spoke2570
    Thanks 🙏
    Am I going to do harm to the speakers if the interconnect cable is in place while using only one speaker?
    No, but understand the cable will be still sending signal to the dimensional woofer and tweeter. I'm not quite sure why you are running off of different A & B channels for each speaker. It seems you would be better to run a dedicated center channel.
  • Spoke2570
    Takers on the second question?
  • Spoke2570
    Thanks. Yes it would be ideal to run them both on one channel, but I think my neighbors would be pissed about my tv noise at night if I didn’t kill one of the speakers. Sportsball and movies need no high-fi. Might integrate a switch for the interconnect to mitigate the second unit entirely.
    Just unplug the cable. You're making this more complicated than it needs to be.
  • Spoke2570
    Thanks for swiftly answering my questions, however odd the setup seems. I think it is safe to assume that most folks on this forum have quite a bit more space in their residences than I do, but I will not give up the space these speakers consume. I like my music clear and full. Best regards.
