about bi-wiring and bi-amping
khanhhuynh4u
khanhhuynh4u Posts: 40
hey guy im new to stereo speakers... but i just got a new polk audio RTi4 hooked up to my computer and i was wondering if i bi-wire or bi-amp will i be able heard any significances changes or maybey just a little bit???
also i have a onkyo 8011 and if i decide to bi-wire or bi-amp i know that i have to get another wire and hook it to the other part of the speakers.....but where on the onkyo receiver?? like both wire running on the A side or one on A and one on B and turning both on at the same time
another question is that can i buy another pair and use 4 speakers at the same time with this onkyo 8011 receiver? i looked for info but havent found any
last can someone please tell me the differece between bi-wiring and bi-amping
thanks alot in advance...i know these are pretty dumb question but i had to ask haha thanks guys
Post edited by khanhhuynh4u on
    F1nut Posts: 52,138
    edited March 2005
    Hit the search feature here and you'll find more than you want to know about the subject.
