Tonearm Cables
Toolfan66
@Toolfan66 what are you needing? RCA to RCA? Din to RCA?2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
That would help, RCA-RCA -
Monoprice RCA’s.
I do still have that Nordost Blue Heaven2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Oops. I didn't realize the section you posted this in. My original post was deleted. My apologies.
Just to pick-a-nit, I would call those "phono cables". Tonearm cables (or wires) are the very small gauge wires inside the tonearm. Now back to our regularly scheduled programming
https://tmraudio.com/search-results-page?q=tonearm&page=1&rb_categories=Interconnects
https://www.musicdirect.com/shop/?query=toneare+cables&fallbackQuery=tonearm+cables
Doh! Well, I did say, "I would call those...". But apparently, I am in the minority!
I don't have anything for you, but I'll be curious to see where you land.Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
Discogs -
Congrats!
I’m curious where all those ground wires are supposed to connect?
I’m just using standard RCA interconnects and the stock ground wire on my SL-1210G at the moment, so not sure where all those spades go.
Brian -
Discogs -
Congrats!
There are additional grounding options depending on your setup. The grounds on either end are removable so you can run without grounds or with just one or two on each end etc.
I won’t put it in till Saturday when I clean my system.
I don’t know about the grounding options making a difference, I might play with it, and see if it changes anything..
Interesting. Thank you!
The ground post on the Technics is a PITA to get to. I’d be having my fingers crossed that it only took one on that end to achieve silence. 🤔
Brian -
I like this option due to experience with mic and intercom systems
Kinda like these,
https://us.v-cdn.net/cdn-cgi/image/fit=scale-down,width=800/https://us.v-cdn.net/5021930/uploads/editor/ij/cfz997aoktkz.jpg
Never seen them with grounds in both ends though. -
I spent the day with this cable, and have to say I’m very impressed with it. I wasn’t really sure how much better it would be from the cables I was using, but so far I’m very happy with it, it’s warmer yet very revealing and deeper on the lower end..
I appreciate Zach giving me a super deal on it..
Thanks!! -
Glad you are enjoying it Larry! I’m sure the PH9.0X + that cable have really stepped up your vinyl game.2 Channel in my home attic/bar/man cave
Just wondering if you did any experimenting with the ground cable configurations, whether or not you noticed any differences and which one you landed on?
I got a Heimdall 2 tonearm cable today that I’ll be installing, hopefully over the weekend. I’ve been so impressed with the H2 interconnects I got for my DAC a few weeks ago that I had to give the tonearm cable a try.
Brian -
I honestly haven't played with it, I just hooked them up complete, using both ground wires, and I am happy with what I am hearing.
I might get to it at some point.. -
Thank you, Larry. That’s good news. I’m hoping to be one-and-done, too.
Brian -
If a particular phono grounding scheme isn't working, it should be evident. It either works, or it doesn't, in my experience. The curveball that I've experienced has been when a step-up-transformer (SUT) is incorporated, since it may require an additional ground wire between the SUT, and the phonostage."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
txcoastal1 wrote: »I like this option due to experience with mic and intercom systems
This configuration totally eliminated the hum I was getting with the single grounds on each end. All good. Many thanks!!!
Edit: I love this place! 👍
Brian
