Tonearm Cables
Let me know what you got.. 😎
  • tratliff
    tratliff Posts: 1,796
    @Toolfan66 what are you needing? RCA to RCA? Din to RCA?
    Toolfan66 Posts: 18,101
    tratliff wrote: »
    That would help, RCA-RCA
  • skipshot12
    skipshot12 Posts: 2,012
    Monoprice RCA’s.
  • stangman67
    stangman67 Posts: 2,328
    I do still have that Nordost Blue Heaven
    treitz3 Posts: 20,032
    edited February 2025
    Oops. I didn't realize the section you posted this in. My original post was deleted. My apologies.
  • jdjohn
    jdjohn Posts: 3,366
    Just to pick-a-nit, I would call those "phono cables". Tonearm cables (or wires) are the very small gauge wires inside the tonearm. Now back to our regularly scheduled programming :)
    jdjohn wrote: »
    https://tmraudio.com/search-results-page?q=tonearm&page=1&rb_categories=Interconnects
    https://www.musicdirect.com/shop/?query=toneare+cables&fallbackQuery=tonearm+cables
  • jdjohn
    jdjohn Posts: 3,366
    Doh! Well, I did say, "I would call those...". But apparently, I am in the minority! :D
  • displayname
    displayname Posts: 1,222
    I don't have anything for you, but I'll be curious to see where you land.
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    Discogs
  • bcwsrt
    bcwsrt Posts: 2,428
    Congrats!
    I’m curious where all those ground wires are supposed to connect?
    I’m just using standard RCA interconnects and the stock ground wire on my SL-1210G at the moment, so not sure where all those spades go.
    Brian
  • displayname
    Toolfan66 wrote: »
    Curious to hear how you like them as you get accustom to them in your system.
    Discogs
  • stangman67
    bcwsrt wrote: »
    Congrats!
    There are additional grounding options depending on your setup. The grounds on either end are removable so you can run without grounds or with just one or two on each end etc.
    I won’t put it in till Saturday when I clean my system.
    I don’t know about the grounding options making a difference, I might play with it, and see if it changes anything..
  • bcwsrt
    bcwsrt Posts: 2,428
    Interesting. Thank you!
    The ground post on the Technics is a PITA to get to. I’d be having my fingers crossed that it only took one on that end to achieve silence. 🤔
    Brian
    txcoastal1 Posts: 13,514
    I like this option due to experience with mic and intercom systems
    I spent the day with this cable, and have to say I’m very impressed with it. I wasn’t really sure how much better it would be from the cables I was using, but so far I’m very happy with it, it’s warmer yet very revealing and deeper on the lower end..
    I appreciate Zach giving me a super deal on it..
    Thanks!!
  • stangman67
    Glad you are enjoying it Larry! I’m sure the PH9.0X + that cable have really stepped up your vinyl game.
  • bcwsrt
    bcwsrt Posts: 2,428
    Just wondering if you did any experimenting with the ground cable configurations, whether or not you noticed any differences and which one you landed on?
    I got a Heimdall 2 tonearm cable today that I’ll be installing, hopefully over the weekend. I’ve been so impressed with the H2 interconnects I got for my DAC a few weeks ago that I had to give the tonearm cable a try.
    Brian
    I honestly haven't played with it, I just hooked them up complete, using both ground wires, and I am happy with what I am hearing.
    I might get to it at some point..
  • bcwsrt
    bcwsrt Posts: 2,428
    Thank you, Larry. That’s good news. I’m hoping to be one-and-done, too.
    Brian
  • jdjohn
    jdjohn Posts: 3,366
    If a particular phono grounding scheme isn't working, it should be evident. It either works, or it doesn't, in my experience. The curveball that I've experienced has been when a step-up-transformer (SUT) is incorporated, since it may require an additional ground wire between the SUT, and the phonostage.
  • bcwsrt
    bcwsrt Posts: 2,428
    edited March 2025
    txcoastal1 wrote: »
    This configuration totally eliminated the hum I was getting with the single grounds on each end. All good. Many thanks!!!
    Edit: I love this place! 👍
    Brian
