SDA sound taking some getting used to.
  • ratpin
    ratpin Posts: 96
    joebass3 wrote: »
    ratpin wrote: »
    I would be interested in a parts list for the crossovers. I can and am willing to solder and assemble.
    I found this old thread with pictures. Are those repo boards still available?
    https://forum.polkaudio.com/discussion/126248/sda-1c-upgrade-complete-with-a-few-pictures?utm_source=community-search&utm_medium=organic-search&utm_term=sda+upgrade
    Gimpod boards are NLA. They pop up used occasionally but I wouldn't hold your breath. The original boards are adequate but, with the new capacitors being larger, you will need to do some planning.
    Capacitors
    2 x 4.4uF
    2 x 12uF
    2 x 20uF
    2 x 40uf
    Resistors
    2 x .5 Ohm (to replace polyswitches)
    2 x 2.7 Ohm
    4 x 7.5 Ohm
    That’s beautiful! Estimated cost?
    Polk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol.
    F1nut Posts: 51,985
    Go online and price it out yourself.
  • joebass3
    joebass3 Posts: 311
    ratpin wrote: »
    Probably $300-$400
  • bcwsrt
    bcwsrt Posts: 2,501
    I spent about $575 just on the parts (including binding posts, though) to rebuild the crossovers in my much simpler, red-headed stepchild RTA 15TLs a couple of years ago now and I continue to be blown away by their sound. Even if it is $300-$400 per speaker for the DIY cost, I would think the 1Cs would be worthy of the expense. Another ~$600-ish, total, for the VR3 plug-and-play version (if you get a discount by not going direct and not through eBay) doesn't seem out of line, either.
    Brian
    pitdogg2 Posts: 27,290
    The @VR3 XO also has much better inductors. The Jantzen C-coils are not cheap and are fantastic inductors. The Supra Rondo wire is also more than a few dollars. There are more than a few man hours in his work.
    To have a plug and play install XO is awful nice ☺️ they're no shortcuts in his work.
    VR3 Posts: 29,545
    Parts cost for inductors average 330 and take 3 to 4 weeks
  • bcwsrt
    bcwsrt Posts: 2,501
    Meant “by going direct,” above.
    With the additional info about the inductor cost, would be a no-brainer for me.
    Brian
    edited February 2025
    bcwsrt wrote: »
    Going from the Erse super Q inductors that Dave (R.I.P.) @westmassguy had me send to him to make as close as possible to the Jantzen C-coils. The C-coils made a very noticable improvement on my SDA 2.3tl's.
    The Erse super Q's I purchased to save a bit of cash during my first build were vastly different. One was almost 20mh the other was almost 16mh. IIRC they were supposed to be 18mh. That difference would more than likely been very noticable. Dave made sure they were both within 1% of each other
    VR3 Posts: 29,545
    The c coil is the literal perfect sda inductor! 🚀
  • bcwsrt
    bcwsrt Posts: 2,501
    bcwsrt wrote: »
    I remembered you telling me that story when I was reading the recent posts in the decato 15TL thread and wondering how that guy’s inductors that he used as-is without measuring would’ve affected his build. Based on what you did to mine with just the posts/caps/resistors, I am convinced no detail goes unnoticed on these old speakers.
    Brian
  • ratpin
    ratpin Posts: 96
    VR3 wrote: »
    Check your inbox
