Adding another pair of SDA 3.1tl.
I have a pair of SDA 3.1tl. Crossovers redone hooked up to high current B&K 200.2 amplifier. It’s my garage system. I can buy another pair a fully functional 3.1 tl for $225. Current speakers are along a common wall 9 ft end to end. I would only be able to place the prospective set inside of the existing speakers. What type of sound would I get using two pairs? Thank you
Welcome!
    BAD!!!
    I do not recommend that set up.
    It’s a good price so I’ll probably scoop them up and store them.
    Not recommended on any level.
    "I would only be able to place the prospective set inside of the existing speakers."
    Can you please post photos of this when you are done giving it a shot?
    rangerjt wrote: »
    That's a great price for some 3.1's!
    rangerjt wrote: »
    The SDA 3.1TL is like the TARDIS: it's bigger on the inside.
    VR3 wrote: »
    Yep, you know he's going to do it...LOL
    edited January 28
    How about on top of each other, upside down and criss-crossed?
    { changed my mind. I had an idea, but it wasn't a good idea, because it was only half an idea, and a novelty at best. Also, I'm not sure how you'd power/cable something like this. And running two Dreadnoughts - I think there might be division by zero in there somewhere, though in theory, it may lead to black paint }
    msg wrote: »
    Probably would work fine if you figure out where and what size to cut the airhole.
    One definitely needs an airhole.
    I believe he had too many air holes.
    From huffing that black paint out of a paper bag..
Welcome!
Welcome!
