Adding another pair of SDA 3.1tl.
I have a pair of SDA 3.1tl. Crossovers redone hooked up to high current B&K 200.2 amplifier. It’s my garage system. I can buy another pair a fully functional 3.1 tl for $225. Current speakers are along a common wall 9 ft end to end. I would only be able to place the prospective set inside of the existing speakers. What type of sound would I get using two pairs? Thank you
    F1nut Posts: 52,382
    BAD!!!
    pitdogg2 Posts: 27,884
    I do not recommend that set up.
  • rangerjt
    It’s a good price so I’ll probably scoop them up and store them.
    treitz3 Posts: 20,353
    Not recommended on any level.
    VR3 Posts: 29,731
    "I would only be able to place the prospective set inside of the existing speakers."
    Can you please post photos of this when you are done giving it a shot?
  • la2vegas
    la2vegas Posts: 772
    rangerjt wrote: »
    That's a great price for some 3.1's!
  • agingboomer
    rangerjt wrote: »
    The SDA 3.1TL is like the TARDIS: it's bigger on the inside.
    F1nut Posts: 52,382
    VR3 wrote: »
    Yep, you know he's going to do it...LOL
    msg Posts: 10,641
    edited January 2025
    How about on top of each other, upside down and criss-crossed?
    { changed my mind. I had an idea, but it wasn't a good idea, because it was only half an idea, and a novelty at best. Also, I'm not sure how you'd power/cable something like this. And running two Dreadnoughts - I think there might be division by zero in there somewhere, though in theory, it may lead to black paint }
  • agingboomer
    msg wrote: »
    Probably would work fine if you figure out where and what size to cut the airhole.
    msg Posts: 10,641
    One definitely needs an airhole.
    F1nut Posts: 52,382
    I believe he had too many air holes.
    Toolfan66 Posts: 18,414
    From huffing that black paint out of a paper bag..
