Projects: what are you all working on?
12346»
    pitdogg2 Posts: 27,617
    edited December 2024
    Hey Carlton, what up?
    If it was me, after I got the new amp, I would of thought hard about getting that old one completely gone through and fixed, all service bulletins, everything. Those are getting harder and harder to find.
  • honestaquarian
    Ivan
    "would of"????
    There is no such thing as "would of"
    "Would have" or the correct contraction "would've" :p
    I did consider what you propose, but; It's expensive and there ain't too many shops left doing it. Then again there was the prospect of the system bing down for a very long time while I waited. I always wanted one of the newer Sunfire Cinema Grand Signatures and I finally got my hands on one that was recapped. So I shall let someone else go through this one. It's already got a bid on it on eBay.
    Would of
    Could of
    Should of
    Good gear is not cheap, no matter what engrush you use...😎
    audioluvr Posts: 6,016
    Ivan
    "would of"????
    Aw man! Too bad your on the opposite end of the continent.
    nooshinjohn Posts: 26,071
    YES I cleaned up the dust! It sat there undisturbed for more than a decade.
    The dust may be what killed it… you can do better.
  • honestaquarian
    honestaquarian Posts: 3,260
    It still works. Just one channel is out. It sat in that location for more than a decade in between the equipment rack and one of the speakers. Why don'tcha come on over and do some cleaning for me since you're so judgemental.............. :p;)
  • honestaquarian
    audioluvr wrote: »
    Ivan
    "would of"????
    https://www.ebay.com/itm/126836168739
  • invalid
    invalid Posts: 1,553
    Fixed the red light of death on the bluesound node2. Just changed a couple of power supply capacitors that are known to go bad.
  • invalid
  • jdjohn
    jdjohn Posts: 3,416
    Replacing the rechargeable batteries in my cordless electric razor.
    Tony M Posts: 11,887
    Horizontal lumber rack.
    For this and more, it's in my barn shed.
    I JUST made "blue" grill inserts for my pair of JBL-L100 Centurys. I now have "white cotton linen" and "Navy Blue" albeit flat grills that look great.
    I cut 2 more pr. of panel inserts to make 2 more colors. I only cut the outer dimensions with inches to spare. I drew the sizes on them and only have to use a Sabre saw to cut away the inside. I'll probably use my table-saw to cut away the outer excess.
  • skipshot12
    skipshot12 Posts: 2,110
    Some maintenance on our 3000GT Spyder.
    Replacing timing belt, pulleys & tensioners along with water pump.
    While there replacing all drive belts including tensioners and pulleys.
    May have been easier if we had pulled the motor.
  • HzTweaker
    HzTweaker Posts: 1,082
    I never knew they came in hardtop convertibles! :o
    2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    VR4 Spyder? The convertible was done by ASC. The 3000GT Spyder is rare, but the VR4 is hen’s teeth rare.
    edited May 2025
    invalid wrote: »
    Copper roof
    If you lived in California, some would steal that roof.
  • WagnerRC
    WagnerRC Posts: 2,219
    nice ride. one of my favs
  • stangman67
    stangman67 Posts: 2,330
    We bought a new (to us) boat. So lots of projects to work on. Adding a second MFD , installing a solar battery charger, putting on a keel guard, deep clean etc.
    Lots of fun but lots of work!
  • skipshot12
    Not a VR4 Spyder, Spyder SL. Couldn’t afford the vr4 spyder.
    Do have a 92 vr4 and it’s next for this fun as **** 60k service.
    I agree on these cars, one of the best cruising GT vehicles ever.
    All are great on long interstate trips.
  • HzTweaker
    I thought VR4s were turbo? Could you still get the active arrow equip on the SLs?
    edited May 2025
    machone wrote: »
    Added a subway module to my model RR.
    I love the Big Boys… just sold my Lionel JLC 4012 before my 3 year old found a creative means to destroy it.
    What scale are you working with?
  • machone
    machone Posts: 1,573
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • skipshot12
    edited May 2025
    Vr4’s were turbo…..
    Twin turbo, twin intercooler, all wheel drive & all wheel steering.
    No Spyder came with active aero.
    Spyder’s we’re only made in 95 & 96.
    The 95 Spyders could be had with ECS but, in 96 they dropped the ECS option.
    The electronic controlled exhaust was also dropped.
    Nice read on the Spyder….
    https://japanesenostalgiccar.com/how-the-mitsubishi-3000gt-spyder-was-made/#:~:text=A non-Spyder VR-4,seems positively insane in 1995.
    With the Spyder conversion adding around 400 pounds it ended up giving them a 50/50 weight distribution.
    Only problem was they were over 4,000lbs, even with the vr4 version they weren’t considered a sports car.
    They were at the top of the heap when it comes to a Grand Touring car of the day, bar none.
    They will cruise above 130 mph all day long.
    A great cannonball run car for sure.
  • HzTweaker
    Insightful! There's a "kid" that drives his Papaws pearl white VR4 to the monthly cars and coffee I go to. It's a very nice car indeed... I know, cool story bro lol :D .
    Viking64 Posts: 7,718
    HzTweaker wrote: »
    Papaws
    Just . . . . . no.
  • stevep
    stevep Posts: 364
    My 92 RT/TT is collecting dust bunnys. It went up on stands for ripped outer CV boot and the while you in there discoveries just kept expanding. Waiting on replacing the transfer case input spool and a stud in the front O2 housing.
    Next project up that I'm more likely to finish on time is new crossover parts for my Monitor 5JR+ since I didn't find the right resistors the Monitor 5's. Ignore the label, those are 33uf caps not 10uf.
  • recoveryone
    recoveryone Posts: 929
    5 years, ongoing bridge project
    https://youtu.be/KE92TYjvqWQ
