Got the turntable itch
A lot of tt people really like the semi-auto feature, including me.
If that was the reason to not check out tables that are full manual…. They do make an add-on for manuals that will lift your tonearm so you’re not bouncing off the end groove. -
By semi-auto, I was referring to exactly what skip said....just lifts the arm. Also, for a dd table it really has a fairly low noise floor, at least to my ears.Yep, my name really is Bob.
Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub.
