Cary SLP-05 LED problem.. ☹️
Toolfan66
Looks like my LED’s are going out on my power supply..
The big bummer is, my 3yr warranty ended on Dec 1st ☹️
It wasn’t doing this yesterday, it started right when I powered it up today. Obviously it doesn’t affect performance, just annoying..
I sent Cary an email today, to see what can be done, I’m actually not fond of the blue lights, but don’t like having them not working either. 😁
I’m kinda hoping they will just send me new LED’s or new meters, I would rather not mail this back for that..
https://youtube.com/shorts/cwrgB0WffTQ?si=54V3gv9A1rFWOg_4
Looks like the led should be easy to replace
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yeah, I opened it up earlier, it's been a while since I have been in there, doesn't look like it would be difficult. i didn't go any further than what you just posted, figured I would wait and see what Cary says first. -
FWIW blue LEDs IME fail more often than red or green.
They were also the hardest color to create. -
Looks like the led bulb is just a regular ought and the tube it connects to is blue- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
When I had my SLP-05 I had the same issue. I talked with a Cary tech who sent me instructions and a couple of LEDs for no charge.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
I couldn't tell for sure.
Nothing bugs me quicker than an LED taking its strobe death march.
That is what I hope they do. -
I think it’s a common problem. I believe the color blue is given off by the color of the vu meters “skin”. Don’t think changing to a green led will have the intended effect.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
I would rather it just be white/clear, and the means to dim it to ones comfort, or turn the light off completely.. -
Yes of courseMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Did you get this fixed?Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Not yet, Steve from Cary reached out to me, sent me the prints on the changes they made and how they are hooked up, and asked if I felt comfortable in tackling this myself.
I told him absolutely, it looks pretty straight forward. but I have yet to hear back from him.
I sent him another email today, hopefully I hear something tomorrow..
I am assuming he is getting all the parts together, and mail them to me.. -
Parts are on the way..
lsi 9's -
1 off bro....
That looks complicated2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Hmm
Not Plug and playMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Still glowing since 2016
Finally had the time today, and tackle this, pretty straight forward, had to eliminate one wire, relocate another, take a diode out, add a cap and resistor, and of course replace the light boxes.
Took a couple hours.
When you turn it on now, the lights come on slowly..
Post edited by Toolfan66 on -
Hi, I'm sorry, but I have the same problem with your Cary Audio.
Could you tell me the value of the resistor and capacitor you added? -
tano_longo wrote: »
I forgot that you also have the LED datasheets -
Exactly what happened to my CAD-120S MKII. VU meters blinked after 2 months then died out. Contacted Cary & they wanted me to send the amp to Cary but I didn't bother to ship since it would be a hassle.
tano_longo wrote: »tano_longo wrote: »
I will see what I have, I do know it’s a 1 Meg Resistor.
If you get ahold of Cary they will sell you the parts needed, including new LED Lights..
