Polk sda 1c crossover modification thread
VR3
For some odd reason I thought I had an existing 1c thread but I couldn't find it in search!
Mahogany substrate, laser cut
Custom delrin caps mounts
Jantzen inductors
Clarity csa capa
Jantzen superes resistors
Supra rondo internal wiring
Supra rondo double run sda cable nl4
Aluminum terminal plates
Jantzen inductors
Clarity csa capa
Beautiful. Someone is going to be happy.
Thank you 😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Full rebuild!
Clarity cmr
Path audio
Jantzen
Supra
Point to point
Dynamat drivers
Resealed enclosure
Hurricane nuts
Black hole 5
Dreadnought 800va
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Are those Lightman1's speakers?
I am not 110% sure this gentleman is on the forum but I do not k ow the complete history of the speakers.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sweet. Just when I'm getting ready to put mine up for sale.
Conradicles wrote: »Are those Lightman1's speakers?
No and yes. I owned them prior to him. Many (well, maybe one or two owned them prior to me). At the time? They were THE most highly modded 1C's...
Let me put it to you this way....If the tops and bottoms were piano black? Probably. If not, then you are well on your way to surpassing what we had at the time.
Tiom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
These initially were stock except for someone who lined the inside of the enclosure with dynamat and I cussed at them while removing it.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I was wondering what all that black stuff was.Political Correctness'.........defined
President of Club Polk -
Impecable work and thread!"Sometimes you have to look to the past to understand where you are going in the future"
Harry / Marietta GA -
Works of art crossovers as usual!
What do you think that dynamat, which is reflective rather than absorbent, would have been doing to the sound quality vs. bare particle board or mdf, which is pretty darn reflective as well?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Thanks guys
Honestly I'm not sure what the thought rationale behind lining the enclosure with dynamat was but it was very difficult to remove lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I don't know if it would have any benefit on panel resonance for MDF but I can definitely see that if you did it you wouldn't want to cover up the grooves that Polk put in the panels, presumably to break up the standing waves?George / NJ
iFi nano iDSD DAC
iPurifier3
Yeah the Monoque design of the latter series was to break up standing waves and the shapes are different to alter resonant frequencies. See how the side walls have no horizontal tracks where as the back does, etc- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Installation steps
Gasket tape terminal opening
Install terminal plate
Route wiring, hook up sda inductor
Reinstall insulation
Reinstall drivers, replace gaskets if oem gaskets are torn or missing
Install crossover, secure wiring
We have sound!
Great job!
Awesome.
Sounding good, especially for cold gear and a fresh crossover 😊
https://youtu.be/o5mpf-AOUAc?si=dtMygEv5UVTI-lMR
Insanely better presentation with the diffraction pads installed, easily heard in the video
https://youtu.be/hZNb0wULqp8?feature=shared
Before hooking them up installed spikes and a cover for the old sda connector
