Polk sda 1c crossover modification thread
For some odd reason I thought I had an existing 1c thread but I couldn't find it in search!
Mahogany substrate, laser cut
Custom delrin caps mounts
Jantzen inductors
Clarity csa capa
Jantzen superes resistors
Supra rondo internal wiring
Supra rondo double run sda cable nl4
Aluminum terminal plates
  • Faustin
    Faustin Posts: 1,151
    Beautiful. Someone is going to be happy.
    VR3 Posts: 29,752
    Thank you 😁
    VR3 Posts: 29,752
    Full rebuild!
    Clarity cmr
    Path audio
    Jantzen
    Supra
    Point to point
    Dynamat drivers
    Resealed enclosure
    Hurricane nuts
    Black hole 5
    Dreadnought 800va
  • Conradicles
    Conradicles Posts: 6,433
    Are those Lightman1's speakers?
    VR3 Posts: 29,752
    I am not 110% sure this gentleman is on the forum but I do not k ow the complete history of the speakers.
    heiney9 Posts: 25,710
    Sweet. Just when I'm getting ready to put mine up for sale.
    treitz3 Posts: 20,360
    No and yes. I owned them prior to him. Many (well, maybe one or two owned them prior to me). At the time? They were THE most highly modded 1C's...
    Let me put it to you this way....If the tops and bottoms were piano black? Probably. If not, then you are well on your way to surpassing what we had at the time.
    Tiom
    VR3 Posts: 29,752
    These initially were stock except for someone who lined the inside of the enclosure with dynamat and I cussed at them while removing it.
    F1nut Posts: 52,406
    I was wondering what all that black stuff was.
  • BlueBirdMusic
    Impecable work and thread!
    Harry / Marietta GA
  • Gardenstater
    Works of art crossovers as usual!
    What do you think that dynamat, which is reflective rather than absorbent, would have been doing to the sound quality vs. bare particle board or mdf, which is pretty darn reflective as well?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    VR3 Posts: 29,752
    Thanks guys
    Honestly I'm not sure what the thought rationale behind lining the enclosure with dynamat was but it was very difficult to remove lol
  • Gardenstater
    I don't know if it would have any benefit on panel resonance for MDF but I can definitely see that if you did it you wouldn't want to cover up the grooves that Polk put in the panels, presumably to break up the standing waves?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    VR3 Posts: 29,752
    edited December 2024
    Yeah the Monoque design of the latter series was to break up standing waves and the shapes are different to alter resonant frequencies. See how the side walls have no horizontal tracks where as the back does, etc
    VR3 Posts: 29,752
    Installation steps
    Gasket tape terminal opening
    Install terminal plate
    Route wiring, hook up sda inductor
    VR3 Posts: 29,752
    Reinstall insulation
    Reinstall drivers, replace gaskets if oem gaskets are torn or missing
    Install crossover, secure wiring
    VR3 Posts: 29,752
    We have sound!
  • Conradicles
    Great job!
  • drop1
    drop1 Posts: 92
    Awesome. B)
    VR3 Posts: 29,752
    Sounding good, especially for cold gear and a fresh crossover 😊
    https://youtu.be/o5mpf-AOUAc?si=dtMygEv5UVTI-lMR
    VR3 Posts: 29,752
    Insanely better presentation with the diffraction pads installed, easily heard in the video
    https://youtu.be/hZNb0wULqp8?feature=shared
    VR3 Posts: 29,752
    A fun set of speakers for sure, thoroughly enjoying it
    https://youtu.be/N-EC2tWr3f0?feature=shared
    VR3 Posts: 29,752
    Before hooking them up installed spikes and a cover for the old sda connector
    VR3 Posts: 29,752
    Last video before I call it a night!
    https://youtu.be/BmZKA-3fOa0?feature=shared
    VR3 Posts: 29,752
    Man I truly find the 1c an incredibly enjoyable speaker!
    1b to 1c conversion
    https://youtu.be/3XQ8uHG9RrE?feature=shared
    VR3 Posts: 29,752
    Insane amounts of bass is produced by these little guys. Truly impressive!
  • Unknown
    VR3 Posts: 29,752
    https://youtu.be/1527dovoU1M?feature=shared
    You might be able to pick up the image and bass here but it easily is filling my 24x15 room with sound
    VR3 Posts: 29,752
    https://youtu.be/h8BjYxEN2vk?si=CdxUOiuOI7oCVTBV
    This is with a 50 dollar receiver powering them to, so much fun
