RT800i sounds muddy
Turmoil6909
in Speakers
Hi everyone. I recently picked up some RT800i's from FB for 70 usd. One of them has a broken tweeter, but other looks fine cosmetically. Even with the broken tweeter one ("right speaker") disabled, the other ("left") speaker sounds very muddy. I have to turn the treble up (a lot) on my amp for it to sound "normal to me" - comparable to my Koss KSC75's for example, but I don't really have anything else to compare to. Is this normal (and maybe just my personal preference) or is something wrong?
Thanks so much!
Thanks so much!
Those tweeters use ferro fluid, may need to change- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thank you. Is it easy to change and worth it (cost, time)?
hey @VR3, since you seem to be one of the modding experts on this form, I was just wondering if you knew how easy it is to replace a RT800 tweeter. Is it just cut a wire and solder the new one on sorta thing? Thanks
Turmoil6909 wrote: »Thank you. Is it easy to change and worth it (cost, time)?
https://forum.polkaudio.com/discussion/185061/ferrofluid-replacment#latest- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Perfect! Thanks so much
So easy.......a caveman can do it???Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
https://youtu.be/GoIiZv1qst4?si=22_RLgZMBVIMxWAy
