RT800i sounds muddy
Turmoil6909
in Speakers
Hi everyone. I recently picked up some RT800i's from FB for 70 usd. One of them has a broken tweeter, but other looks fine cosmetically. Even with the broken tweeter one ("right speaker") disabled, the other ("left") speaker sounds very muddy. I have to turn the treble up (a lot) on my amp for it to sound "normal to me" - comparable to my Koss KSC75's for example, but I don't really have anything else to compare to. Is this normal (and maybe just my personal preference) or is something wrong?
Thanks so much!
Thanks so much!
Those tweeters use ferro fluid, may need to change- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thank you. Is it easy to change and worth it (cost, time)?
hey @VR3, since you seem to be one of the modding experts on this form, I was just wondering if you knew how easy it is to replace a RT800 tweeter. Is it just cut a wire and solder the new one on sorta thing? Thanks
Turmoil6909 wrote: »Thank you. Is it easy to change and worth it (cost, time)?
https://forum.polkaudio.com/discussion/185061/ferrofluid-replacment#latest- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Perfect! Thanks so much
So easy.......a caveman can do it???Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
https://youtu.be/GoIiZv1qst4?si=22_RLgZMBVIMxWAy
