As a road warrior, the balancing is equally important. That's why I only buy tires from discount tire as they rotate and balance for free for the life of the tire- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Who is tightening lug nug nuts every 100 miles?
Not every 100 miles. Just once. After mounting a tire on a car (at least when the tires are on alloy wheels), one is supposed to check torque after about 50 miles and re-torque to spec. The place we get our tires (which is very good) insists on it... but, on the bright side, they'll essentially drop everything & check "in real time" so to speak when one brings a car back for re-torquing.
It's not a bad idea to check torque now and again, though.
The tire place also rotate tires they sold for free and will also put on snow tires they sold for free -- and that's the problem.
I did my own rotation this time because, despite my best intentions to take the car in and get 'em done while Mrs. H was in Africa... I didn't
Now they're hella busy with snow tire installations, and so I decided to do 'em myself. I will probably throw Mrs. H's snows on, too, for the same reason.
My tires are the Michelin Crossclimate 2 which are really nice all weather, all year (!?!) tires -- but they need to be rotated every 3k miles, or one won't get the tread life of which they're capable. I take Michelin & the tire place at their words.
"If you don't have a torque wrench, you can use the lug wrench that came with the car, as it's designed to prevent over-torquing."
Unless you're following behind "Uncle Torque".Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
... or stick a big ol' piece o'pipe on the shank of it."If you don't have a torque wrench, you can use the lug wrench that came with the car, as it's designed to prevent over-torquing."
mrbigbluelight wrote: »Them
If that makes your mind curious, check out the Netflix Series called Ancient Apocalypse. -
I believe that's the series with Graham Hancock.
I personally enjoy the heck
out of Hancock's work.
80% of Commenters will dismiss ANYTHING that he does simply because "He doesn't have a degree in Archaeology !"
Or Astronomy.
Or Oceanology.
They base their arguments on credentials and ignore that frequently Hancock is merely raising valid questions.
Interesting interviews on Rogan's podcast.
Sal Palooza -
Mmmm….gravy!
Garnished with bacon on a stick and I’m in2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
^^^ had a 1977 Ford Ranger 4×4 back in the day. My father in law used a electric gun to put on the lug nuts & I questioned it. He said it was fine. It started to shake real bad on i95 & it was scary. I pulled over. Sure enough. They came looseRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
so adorable!
Until I saw this last night, I hadn't realized that RCA lay behind the iPOD dock idea oh-so-long ago!
Vintage Advertising For The RCA Model 1BT2 Transistor Radio & Models BCS-4 And RK222 Transichargers In The Troy Alabama Messenger Newspaper, December 12, 1958 by Joe Haupt, on Flickr
Vintage RCA Victor Model 1BT24 Transistor Radio With Model BCS-4 Transicharger, Made In USA, Circa 1958 by Joe Haupt, on Flickr -
oh, and this just in from around the corner @ ASR:
________________
way around the corner.
…and over the edge.
lsi 9's -
Appearances to the contrary, I actually really do try not to channel my inner 12 year old, even in the context of humor.
That said.
1) that clearly doesn't stop others.
2) I don't claim that I never give in to the temptation.
As seen on Yahoo, moments ago.
Holy!
That's like a scene from one of the Jurassic Park movies right before someone goes missing.I disabled signatures.
