Bass stuck on full volume
The bass light indicator on my Polk React is stuck on full+
The handset works with all the other functions.
When I ask Alexa to turn the bass down it says it's already at the minimum.
We can't watch movies with any bass in them as it's unbearably loud!
Best Answer
  • Irrenhaus
    Irrenhaus Posts: 1,102
    Answer ✓
    Have you try a factory reset.
    Resetting factory settings
    Perform this procedure if the display is abnormal or if operations cannot be performed.
    Various settings are reset to the factory default values. Make settings again.
    Press and hold the Action button until the light bar turns orange (about 25 seconds).
    The light bar turns blue indicating the reset sequence has started.
    This unit automatically restarts in a factory default values.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Answers
