Center channel recommendations for a polk monitor 4.6 setup
jj1999
I have a 5.1 setup with a pair of Monitor 4.6 speakers and monitor 4As for the sides. Does anyone have any recommendations for a good matching center channel that I can find for sale? Preferably second hand.
I read about the CS350LS and CS400i, but I can't seem to find any available for sale in my price range. Looking to spend under $150 since I got the monitors for just $70.
Answers
I'd look for another pair of what you're using now. I used 6 JBL HLS610's in a 6.2 set up. I never felt I was missing anything without a dedicated center channel.
I thought about that, but I would prefer a center channel just because they are always sold in pairs and so I'd have to buy 2 and end up with one that just never gets used.
Another option I have considered would be to use one of the monitor 4s as my center (I assume they match closely to the 4.6) and then use some old RM6751 satellites that I have sitting around for the side channels. I know they probably wouldn't match well but I figured it would be good enough since they don't get much use anyway. -
Buy the pair hook them up in series to use both. That way you can spread them apart to get a wider soundstage.
I did that ^^^^ years ago with good results. As I waited for a Cs400 & then I upgraded to Cs400i both great CC speakers.Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
I've heard nothing but good on the Cs350ls but never had one. I'm still running a Cs1000p which is just ok IMO.Randy-Maine
by David WMG
These were recommendations from Polk Audio a while back.Stan
Main 2ch:
HT:
Other stuff:
I am surprised they recommend those, aren't they a different driver size? Still, I might give them a shot.
I attempted to use one of my monitor 4s as a center channel and noticed it sounded terrible. Unfortunately it looks like the woofer was seized up. Fortunately the other one that I had was working and it sounds great in the center. -
It's really on how they are voiced. Driver size makes a difference in frequency response like more low end, BUT with the center it is more about voices/dialogue and not bass low end. All should reproduce all but the deepest human voice octave, most go down to 50-60Hz.
Thanks, I also do not see the 4.6 series 2 on those lists anyway. I figured I would probably go with whatever they recommend for the monitor 5, that's probably the closest thing right? -
Monitor4 or 5jr.
CSiA6 are dang nice centers. I run one now. They are on the big side, They were $150 or less during clearance. -
The CSiA6 are what I have been eyeing. Do you happen to have experience with the CSi3 or the CSiA4? There are a lot more available for sale locally in my area. Just trying to decide if it is worth the downgrade.
I do not. I've used CS350 and the CSiA6
If the CSiA4 is available I'd give it a try. -
I have done both: used my 4's as a (dual) center and then replaced with a CS300 (and moved the 4's to bedroom duty). See sig.Yamaha RX-A2050 AVR (5.1.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelKlipsch SPL-120 subwooferAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets
How did the sound compare? Are you happy with the CS300? I am currently looking at a CSIa6 someone is selling locally for $100.
I just got these monitor 4.6s and I love them so far! -
The CSiA6 is a terrific performer and it matches beautifully (both sonically and aesthetically) with my SDA-2B Studio, Monitor 11T, Monitor T90 Euro setup.The arc of the moral universe is long, but it bends towards justice.—Martin Luther King Jr.
I bought the CS300 precisely because it "matches" well with vintage Polk speakers.How did the sound compare? Are you happy with the CS300? I am currently looking at a CSIa6 someone is selling locally for $100.
