Center channel recommendations for a polk monitor 4.6 setup
I have a 5.1 setup with a pair of Monitor 4.6 speakers and monitor 4As for the sides. Does anyone have any recommendations for a good matching center channel that I can find for sale? Preferably second hand.
I read about the CS350LS and CS400i, but I can't seem to find any available for sale in my price range. Looking to spend under $150 since I got the monitors for just $70.
Answers
    pitdogg2 Posts: 27,502
    I'd look for another pair of what you're using now. I used 6 JBL HLS610's in a 6.2 set up. I never felt I was missing anything without a dedicated center channel.
  • jj1999
    jj1999 Posts: 10
    I thought about that, but I would prefer a center channel just because they are always sold in pairs and so I'd have to buy 2 and end up with one that just never gets used.
    Another option I have considered would be to use one of the monitor 4s as my center (I assume they match closely to the 4.6) and then use some old RM6751 satellites that I have sitting around for the side channels. I know they probably wouldn't match well but I figured it would be good enough since they don't get much use anyway.
    edited October 2024
    Buy the pair hook them up in series to use both. That way you can spread them apart to get a wider soundstage.
  • boston1450
    boston1450 Posts: 7,758
    I did that ^^^^ years ago with good results. As I waited for a Cs400 & then I upgraded to Cs400i both great CC speakers.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    I've heard nothing but good on the Cs350ls but never had one. I'm still running a Cs1000p which is just ok IMO.
    Randy-Maine
    by David WMG
  • skrol
    skrol Posts: 3,475
    These were recommendations from Polk Audio a while back.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jj1999
    jj1999 Posts: 10
    I am surprised they recommend those, aren't they a different driver size? Still, I might give them a shot.
    I attempted to use one of my monitor 4s as a center channel and noticed it sounded terrible. Unfortunately it looks like the woofer was seized up. Fortunately the other one that I had was working and it sounds great in the center.
    It's really on how they are voiced. Driver size makes a difference in frequency response like more low end, BUT with the center it is more about voices/dialogue and not bass low end. All should reproduce all but the deepest human voice octave, most go down to 50-60Hz.
  • jj1999
    jj1999 Posts: 10
    edited November 2024
    skrol wrote: »
    Thanks, I also do not see the 4.6 series 2 on those lists anyway. I figured I would probably go with whatever they recommend for the monitor 5, that's probably the closest thing right?
    Monitor4 or 5jr.
    CSiA6 are dang nice centers. I run one now. They are on the big side, They were $150 or less during clearance.
  • jj1999
    jj1999 Posts: 10
    The CSiA6 are what I have been eyeing. Do you happen to have experience with the CSi3 or the CSiA4? There are a lot more available for sale locally in my area. Just trying to decide if it is worth the downgrade.
    I do not. I've used CS350 and the CSiA6
    If the CSiA4 is available I'd give it a try.
  • StantonZ
    StantonZ Posts: 453
    I have done both: used my 4's as a (dual) center and then replaced with a CS300 (and moved the 4's to bedroom duty). See sig.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • jj1999
    jj1999 Posts: 10
    StantonZ wrote: »
    How did the sound compare? Are you happy with the CS300? I am currently looking at a CSIa6 someone is selling locally for $100.
    I just got these monitor 4.6s and I love them so far!
  • The CSiA6 is a terrific performer and it matches beautifully (both sonically and aesthetically) with my SDA-2B Studio, Monitor 11T, Monitor T90 Euro setup.
  • StantonZ
    StantonZ Posts: 453
    jj1999 wrote: »
    I bought the CS300 precisely because it "matches" well with vintage Polk speakers.
