Center channel recommendations for a polk monitor 4.6 setup
I have a 5.1 setup with a pair of Monitor 4.6 speakers and monitor 4As for the sides. Does anyone have any recommendations for a good matching center channel that I can find for sale? Preferably second hand.
I read about the CS350LS and CS400i, but I can't seem to find any available for sale in my price range. Looking to spend under $150 since I got the monitors for just $70.
Answers
  • jj1999
    jj1999 Posts: 10
    I thought about that, but I would prefer a center channel just because they are always sold in pairs and so I'd have to buy 2 and end up with one that just never gets used.
    Another option I have considered would be to use one of the monitor 4s as my center (I assume they match closely to the 4.6) and then use some old RM6751 satellites that I have sitting around for the side channels. I know they probably wouldn't match well but I figured it would be good enough since they don't get much use anyway.
  • Unknown
    edited October 2024
  • boston1450
    boston1450 Posts: 7,759
    I did that ^^^^ years ago with good results. As I waited for a Cs400 & then I upgraded to Cs400i both great CC speakers.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    I've heard nothing but good on the Cs350ls but never had one. I'm still running a Cs1000p which is just ok IMO.
    Randy-Maine
    by David WMG
  • skrol
    skrol Posts: 3,493
    These were recommendations from Polk Audio a while back.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jj1999
    jj1999 Posts: 10
    I am surprised they recommend those, aren't they a different driver size? Still, I might give them a shot.
    I attempted to use one of my monitor 4s as a center channel and noticed it sounded terrible. Unfortunately it looks like the woofer was seized up. Fortunately the other one that I had was working and it sounds great in the center.
  • jj1999
    jj1999 Posts: 10
    edited November 2024
    skrol wrote: »
    Thanks, I also do not see the 4.6 series 2 on those lists anyway. I figured I would probably go with whatever they recommend for the monitor 5, that's probably the closest thing right?
  • Unknown
  • jj1999
    jj1999 Posts: 10
    The CSiA6 are what I have been eyeing. Do you happen to have experience with the CSi3 or the CSiA4? There are a lot more available for sale locally in my area. Just trying to decide if it is worth the downgrade.
  • Unknown
  • StantonZ
    StantonZ Posts: 454
    I have done both: used my 4's as a (dual) center and then replaced with a CS300 (and moved the 4's to bedroom duty). See sig.
    Yamaha RX-A2050 AVR (5.1.2); LG OLED77C2 4K TV
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
    Klipsch SPL-120 subwoofer
  • jj1999
    jj1999 Posts: 10
    StantonZ wrote: »
    How did the sound compare? Are you happy with the CS300? I am currently looking at a CSIa6 someone is selling locally for $100.
    I just got these monitor 4.6s and I love them so far!
  • agingboomer
    The CSiA6 is a terrific performer and it matches beautifully (both sonically and aesthetically) with my SDA-2B Studio, Monitor 11T, Monitor T90 Euro setup.
  • StantonZ
    StantonZ Posts: 454
    jj1999 wrote: »
    I bought the CS300 precisely because it "matches" well with vintage Polk speakers.
