Monitor 4 wall mounting
jj1999
Anyone have suggestions for mounting the monitor 4s on a wall? I have seen the clamping bookshelf mounts, but I would need mine to tilt down a bit and the monitors are heavy, so I would be concerned about them slipping out over time. Maybe there is one that clamps front to back, or has some kind of stopper on the front?
I did notice mine have 2 holes on the back that the previous owner must have added, with metal threads inside. Not sure what kind of mount you would use for these:
Answers
These are good wall mounts. You may be able to use less expensive ones as these are able to
support speakers weighing 55 lbs.
https://www.amazon.com/B-Tech-BT77-Ultragrip-Speaker-Swivel/dp/B004DCAOHK/ref=asc_df_B004DCAOHK/?tag=hyprod-20&linkCode=df0&hvadid=693569091832&hvpos=&hvnetw=g&hvrand=12677909551430820943&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9024585&hvtargid=pla-350672747945&psc=1&mcid=6b4f5e3dd1343ca29207080e4369c324 -
I have used something very similar to THAT ^^^
Don't screw something to/into the back of your 4's.Yamaha RX-A2050 AVR (5.1.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelKlipsch SPL-120 subwooferAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
Strangely enough, someone already did that. The previous owner added 2 threaded insert holes to the back of the 4s. They appear to be for mounting but I am not sure. You can't see the threaded inserts in the picture below but they are there. I am wondering if there is a mount that clamps but also secures into one of those threads for extra security, since I will have to tilt them forward quite a bit.
