Nelson Pass First Watt amps
I'm intrigued from what I've read about his design philosophy in development of his First Watt line of amps.
All class A & low power to boot. Not designed to drive all speakers, mainly those with relatively high impedence
My speakers are 87db sensitivity & from what I can gather are right at the cutoff for those amps
I've been looking at the F7 & F8. Anyone have any first hand experience with his First Watt amps & in particular the two I mentioned.
    txcoastal1 Posts: 13,499
    @heiney9 Brock and Doc Hardy are the ones that I know of with First watt knowledge
  • TEAforONE
    TEAforONE Posts: 1,031
    I own and am currently running two FW amps in two different systems. Unfortunately,the two I own are not those models. I'm running an F5,and a J2. I rotate 3 different speakers. Currently the F5 is driving Hornshoppe Great Horned Heils.( about 93db sensitivity). The J2 is driving Nola Boxer 2's.(about 90db) The third pair are Graham Chartwell LS 3/5.(about 84db)
    These amps work great for what I ask them to do. I don't listen to music at 100db anymore. I'm usually in the 85db if I'm rocking out. The FW amps are tremendous sounding in my opinion. I was also considering an F7, however a used J2 popped up first. Best of luck with your search. I look forward to your choice,and impressions.
  • pearsall001
    pearsall001 Posts: 5,218
    TEAforONE wrote: »
    Thanks for the info. I'm pretty much in the same camp as you that I don't need or even want to blast my system. My speakers are 87db so I believe the FW amps would be more than up to the task
  • CoolJazz
    CoolJazz Posts: 572
    I have a pair of both the F1 and F2 models, that being current source amps, are not for most speaker systems. Then a pair of DIY F4's that are the only super high power amps amongst my FW amps....being I think 40w models when run as monoblocks. :) Or is it 25w? Can't remember as it's way more power than I need. DIY'd several models and played with them. But again, not the models you've got an eye on.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • TEAforONE
    One suggestion I’d like to make. FW amps run on the rather warm side. Good ventilation is a must. I originally purchased the J2 to run in my main system. That’s where it will be in the winter months. It warms my small listening room considerably! So,for the summer months it resides in the system in our finished basement. I keep both amps free air on amp stands.
  • CoolJazz
    CoolJazz Posts: 572
    If the OP is interested in a F7, then you might want to keep an eye on the auction one on eBay. Closing Monday during the day.
    CJ
  • TEAforONE
    CoolJazz wrote: »
    CJ
    That’s a very recent build. It has the new faceplate with only 1 light.
  • TEAforONE
    The F7 sold for $1824. That was a great deal!
  • GlennDog
    GlennDog Posts: 3,149
    Did First Watt morph out of the Aleph Volks line?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • TEAforONE
    GlennDog wrote: »
    That's a great question. I did a little research, and Pass Labs was founded in 1991,and started producing the class A, Aleph series of single ended amps. That was where he started. I believe the spirit behind FW was he wanted to experiment with simple low power amps, in a very limited build situation,but separate from Pass Labs. I think he built all FW amps himself until 2016,or 17'. I know my FW F5 was built by him.( literally) I'm pretty sure my J2 was built by the Pass Labs production team.
  • Navy_Goat
    Navy_Goat Posts: 375
    Interesting discussion here. I have been trying to talk myself in to a FW DIY build over the past few months. Earlier in the discussion @pearsall001 mentioned that the FW ams are low power and built to work well with high impedance speakers. Can anyone expand on the high impedance logic? Thanks,
    Caleb
    SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
    pitdogg2 Posts: 26,917
    Maybe he meant high efficiency. I remember seeing some speakers years back that were high 90's low 100's..
    There used to be 16ohm speakers as well.
  • maxward
    maxward Posts: 1,668
    @Navy_Goat one of these probably would be a great match for Zu speakers.
  • TEAforONE
    I know Nelson Pass said with the F5,it can dip down to 2ohms without misbehaving.
  • Navy_Goat
    That makes sense. Any FW clone I build would be for a pair of speakers that advertises 97db efficiency and 12 ohm impedance. I think they would be a good match.
    In the interest of domestic tranquility around my house I will wait a little while as I just finished another kit amp build, but I will get to a First Watt soon enough. At least I will if I don't get distracted.
    You'll have to match with a pre the doesn't have a hair trigger...
    This does make me interested in a DIY
  • TEAforONE
    It appears the F7 on eBay is back up for sale. No affiliation.
  • kevhed72
    kevhed72 Posts: 5,125
    I located an F7 for sale on the Music Room. While the space heater feature is a bit concerning, I am intrigued because I have never owned a pure class A amp. The F7 comes with some mixed reviews on Audiogon, but it seems this may be due to speaker/component pairing. Alas, I will seek the input of my fellow Polkies on this combination:
    Polk L200
    Pair of REL T7 subs
    Dehavilland Ultraverve pre
    MIT s2 and s3 cables throughout.
    VR3 Posts: 29,383
    As long as you like the pass labs house sound you should be fine.
    I have had a few in and out over the years. If it's old you absolutely will want it to be serviced.
    I've determined they are just not a good match for my Focals
  • kevhed72
    VR3 wrote: »
    How would describe the house sound ?
    VR3 Posts: 29,383
    edited October 2024
    The x series I have had thru here have all had a slow fat sound that borders on muddy. These are with amps that were serviced
    Ymmv
    billbillw Posts: 7,442
    I'd caution against using a relatively low powered Class A amp with a pair of L200. They are not exactly efficient, and they are 4ohm nominal, correct? Doesn't sound like a match in heaven.
  • kevhed72
    They are 85.5 db efficient I believe.
    FWIW I do most listening at lower volumes these days.
    VR3 Posts: 29,383
    edited October 2024
    I think you need to approach this from a service stand point.
    How old is the amp? 20 to 30 years? Has it ever been serviced? If not you could be looking st 750 to 2500 to fully service some of those old amps.
    This can help determine resale and pricing.
  • pearsall001
    I always wanted to give one of those amps a go but my speaker choices pretty much ruled them out. Just not enough oomph. Maybe someday if my taste in speakers change.
  • maxward
    First available in 2016, so age is not yet a big factor.
  • WagnerRC
    WagnerRC Posts: 2,199
    edited October 2024
    I have an Aleph J sitting here in near new condition that has a nice sound. I would be willing to make a deal to a long time Polkie at a fair price.
    found this old thread for reference.
    https://forum.polkaudio.com/discussion/199702/review-first-watt-aleph-j-power-amp
  • jdjohn
    jdjohn Posts: 3,315
    WagnerRC wrote: »
    Yep, that's my thread from when I first received my Aleph J (or DIY clone of one). My Mezzo Utopia speakers are 92.5db efficient, and the Aleph J powers them quite sufficiently. The amp did sort of run-out-of-gas at really high volumes, but never went into clipping. My primary listening is folk, singer/songwriter, acoustic, classic rock, and classical, and the Aleph J excels at that - even at lower volumes. It might not do as well with EDM or rap at big volumes.
    heiney9 Posts: 25,395
    Pass Labs and First Watt do not have a "house sound". They are all completely different circuit designs using different parts. Sometimes (especially with First Watt) to achieve different outcomes. You will always hear Nelson saying they each sound different depending on the flavor that suits the listener. "We don't build one amp for everything or everyone, we build several types of amps all sounding different"
    He had semi south make a special run of Static Induction Transistors. He bought they entire lot they made special for his use.
    He's used them all (saving some for future repairs if necessary). The First Watt SIT amps are very highly regarded.
