Looking for a new HT processor that excels with music too
DaveHo
DaveHo Posts: 3,583
Yeah, I know, those two things are usually mutually exclusive. None the less, my main rig is dual purpose. I've been using a circa 2012 Pioneer sc1523 combined with a few different preamps with HT bypass. It's been OK, but the pioneer is getting long in the tooth, and frankly I'd like to simplify things. Only interested in processors. The pioneer's amps haven't played one note since day one. Zone 2 abilities would be a bonus, but have other means for that if needed. Would like to go new. Used is okay if a current model. I've read good things about Anthem. Budget is 4k ish.
Fire away, and thanks!
  • Emlyn
    Emlyn Posts: 4,813
    The Anthem AVM70 8K should tick the boxes for you at $4K new. I have a Marantz AV8805A but that is a bit more expensive. I am happy with that in direct mode. I would not consider the Marantz 7706 model to be equal to either of those for music but is excellent for home theater.
    VR3 Posts: 29,539
    One with ht bypass so you can add a 2 channel preamp 😁
  • DaveHo
    DaveHo Posts: 3,583
    @VR3 , noooooooo! Besides, that's the preamps job, not the HT processor.
  • DaveHo
    DaveHo Posts: 3,583
    Emlyn wrote: »
    That's the direction I'm leaning.
  • DaveHo
    DaveHo Posts: 3,583
    @Emlyn , AC4L has the Marantz for $2400 refurbished. I'm down with refurbished gear. Have bought many over the years, no issues. I realize you may not have heard both. What do you think gives the Marantz a leg upon the Anthem AVM70?
  • Emlyn
    Emlyn Posts: 4,813
    I might have have got the Anthem if they had been available when I was looking for a new processor. Pandemic supply shortages prevented that.
  • DaveHo
    DaveHo Posts: 3,583
    Just noticed the AC4L is the 8805, not the 8805A. Time to investigate.
    nooshinjohn Posts: 25,991
    Arcam AV41 is cream of the crop…
  • sgmsmg
    sgmsmg Posts: 556
    Anthem is 20% off at Audio Advice if you decide to go that route.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • Their processors are known for great sound and reliability. You might also want to check out Marantz or Denon for similar options. Both brands have solid AV processors, and with your budget, you could get something new with all the features you're after. I’d recommend looking at their latest models for more modern tech and performance improvements.
