Connecting sub woofer to a pre amp/amp combo
Flashg58
I have a separate amp and pre-amp system. Got a good condition Polk Audio DSW Pro model powered sub. Any idea how to connect? The manual doesn't have instructions for my set up. I know this is basic...Thanks!
Which model preamplifier and power amplifier are you using? This will indicate if it has a filtered sub-out or not.
Adcom GFA-545 amp, Schiit saga 2 pre
That should be a good sounding combination. You would want to follow this from the Polk owner's manual:
It shows a line level connection from the preamp's outputs going to the corresponding line level inputs on the subwoofer. Then line level from the subwoofer's outputs to the corresponding line level inputs on the power amplifier. The "LFE yes/no" switch on the subwoofer is set to "no".
You're welcome
