RTi8's and CSi A6 - CO and Tweeter Upgrades?
abearden278
Hello All!
I have a set of RTi8's and a CSi A6 center that I am curious about modding.
Great shape. Nothing done to them as of yet.
Caps and resistors-
Film resistors and Nedlab 400v caps be a good choice?
As for the tweeter part of this, is there a recommendation for replacements? One of mine is damaged so I figured I would replace them all at the same time and if there was a specific one recommended by the community I would give it a whirl. Yes, I know.... I might not need to upgrade/change them all. But I figured if I am going to do this. I might as well just do it all.
Caps and resistors-
Hell no!Film resistors and Nedlab 400v caps be a good choice?
Non-inductive audio grade resistors such as Vishay-Mills. For caps Sonicap Gen I, Clarity CSA or Janzten Superior-Z are good choices.
As far as I know there are no suitable replacement tweeters other than the originals. -
Ahhh, thank you! I was going to go down the wrong path!
I'm still learning.
A lot to learn.
Completely new to this -
What is thisabearden278 wrote: »Hello All!
Caps and resistors-
Welcome to the forum! What is this system used for and what are the other components? TBH many of us would suggest putting the money you would use for the crossovers along with whatever you can get for the speakers and upgrading. Many of us find that series too bright:
Good luck!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Home theater
Movies/streaming only
RTi8 x2
CSi A6
Paradigm SE Atom Monitor x2
Speedwoofer 10e
Denon S960H -
Ahh, that would probably help
Home theater setup
Denon S960H
RTi8 x2
CSi A6
Paradigm SE Monitor Bookshelf x2
Speedwoofer 10e
Open concept living room flowing into the kitchen and dining area.
