RTi8's and CSi A6 - CO and Tweeter Upgrades?
Hello All!
I have a set of RTi8's and a CSi A6 center that I am curious about modding.
Great shape. Nothing done to them as of yet.
Caps and resistors-
Film resistors and Nedlab 400v caps be a good choice?
As for the tweeter part of this, is there a recommendation for replacements? One of mine is damaged so I figured I would replace them all at the same time and if there was a specific one recommended by the community I would give it a whirl. Yes, I know.... I might not need to upgrade/change them all. But I figured if I am going to do this. I might as well just do it all.
    F1nut Posts: 51,793
    edited July 2024
    Hell no!
    Non-inductive audio grade resistors such as Vishay-Mills. For caps Sonicap Gen I, Clarity CSA or Janzten Superior-Z are good choices.
    As far as I know there are no suitable replacement tweeters other than the originals.
  • Ahhh, thank you! I was going to go down the wrong path!
    I'm still learning.
    A lot to learn.
    Completely new to this
  • rooftop59
    rooftop59 Posts: 8,121
    What is this
    Hello All!
    Caps and resistors-
    Welcome to the forum! What is this system used for and what are the other components? TBH many of us would suggest putting the money you would use for the crossovers along with whatever you can get for the speakers and upgrading. Many of us find that series too bright:
    Good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • Home theater
    Movies/streaming only
    RTi8 x2
    CSi A6
    Paradigm SE Atom Monitor x2
    Speedwoofer 10e
    Denon S960H
  • Ahh, that would probably help
    Home theater setup
    Denon S960H
    RTi8 x2
    CSi A6
    Paradigm SE Monitor Bookshelf x2
    Speedwoofer 10e
    Open concept living room flowing into the kitchen and dining area.
