Fm tuner input
bb1105
bb1105 Posts: 2
edited May 2024 in Electronics
I have a vintage yamaha tuner with a 75 ohm, a and b dual unbalanced input that rcas don't go in and the coax with threads doesn't seem to, how should it be hooked up?
Answers
    F1nut Posts: 52,305
    msg Posts: 10,622
    Wow, I didn't know this was a thing. I've only seen two connection types for this. Good info, @F1nut
    @bb1105 - I'm curious about this, could you post photos or a model number?
    I thought you were having trouble connecting the tuner to a receiver, but couldn't determine from your post what you meant without more info.
    pitdogg2 Posts: 27,778
    edited May 2024
    Many Yamaha tuner or receivers had that type of connection. When new they came with a pigtail that had a coax F type connection on one end and the slip on connection for the tuner or receiver on the other. They were quite common back in the day.
    msg Posts: 10,622
    I've only ever seen that spade to coax transformer shown here at the 3 o'clock position. I didn't know about the other connection types. interesting.
    That would be a 75 ohm to 300 ohm balun @msg.
    msg Posts: 10,622
    I know, dude lol :smiley:
    I only used the word transformer because that's what's stamped on it.
    mhardy6647 Posts: 35,523
    edited May 2024
    baluns convert a BALanced connection to an UNbalanced connection. Usually with appropriate impedance matching. B)
    In this case, 300 ohm balanced to 75 ohm unbalanced.
    The European 'standard' equivalent to our 75 (ish) ohm "F" connector for cable TV (OTA downleads, too) was/is the PAL connector. Yamaha tended to put PALs on everything, to the consternation of us in the Colonies who were/are still pretty much all "F"d up. ;)
    EDIT: If I get suitably bored* later today, I'll post some photos of some of my "workarounds" to the vagaries of FM signal input 'standards'. Trigger warning: they are generally not pretty. :#
    _____________
    * which, in this case, actually means, "when I get tired of doing what I should be doing out in the garden" today. :blush:
    msg Posts: 10,622
    I did not, however know the definition of "balun".
    I thought that was that grill thing that whales have for screening krill.
    msg wrote: »
    Whales -- and some BMWs.
    B)
    The best thing about that photo I just posted above (from 2019?!?!) -- the link from Road & Track from whence it came also provided the invaluable information that, at least back in 2019, BMW's design director was named Adrian von Hooydonk. Who needs fiction (or AI) when we have real life, eh?
    B)
    Viking64 Posts: 7,771
    Hooydonk is nobody's business but our own.
    msg Posts: 10,622
    msg wrote: »
    B)
    Yes, that. Baleen B)
