So I built this...
steveinaz
steveinaz Posts: 19,545
edited May 2024 in The Clubhouse
Bluetooth 5.0, wireless speaker, using MTM .50 cal ammo box, Dayton audio, and Kicker driver components. It sounds great!
Post edited by steveinaz on
«13
    msg Posts: 10,452
    edited May 2024
    Noice!
    I've wanted to build something like this for a while now, myself.
    Is this one of a pair with SDA technology?
    billbillw Posts: 7,659
    Looks nice Steve! I like how you store the paperwork inside too!
    I'm sure you probably realize you'll need to keep an eye in those anchors holding tight since the expansion isn't within the case material.
    msg Posts: 10,452
    I heard Larry's Rings are on order.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    I'm calling the ATF
    xschop Posts: 5,224
    Where's the BH5?
  • gmcman
    gmcman Posts: 1,852
    edited May 2024
    This needs a review. Might I suggest Amir at ASR?
    He won't listen to it, will just hook a scope to it, show some distortion, then get the rest of his loyal members to give him the "way to go, good find, can't believe people listen to this stuff" scenario. Imagine how bad it would review...."sound" if it had tubes. B)
    @steveinaz Nice work! Did you design the boards as well? Looks like a nice, clean build.
  • steveinaz
    The BT amp board, battery/charging board, and rear panel are all Dayton audio products. They come with all of the ribbon connectors---it's plug-n-play pretty much. The amp I picked was the 2 ch 30w, it was on sale for $29! This will be our pool/beach boom box. I wanted something like the Turtlebox, but figured I could build something better for way less money. This was 1/2 the price of a TB.
  • Jstas
    Jstas Posts: 14,990
    Sweet
    I found a box of components to do something similar over the weekend. I got it in 2018 and apparently forgot about it.
    Gonna build a bluetooth "boom box" with a 50x2 and 100x1 so I can put a small sub in it too. Got some Tang Band full range drivers and a Peerless sub for it.
    Expert Moron Extraordinaire
    Jstas wrote: »
    Sweet
    Gonna need a big battery for that!
    msg Posts: 10,452
    It'll add ballast!
  • steveinaz
    edited May 2024
    billbillw wrote: »
    The anchors are there just to cover the sharp screw points. Eventually I'll run bolts/nuts, but for now the screws are holding well. I left an empty area on the right side for the laptop "style" charging brick for the 18650's.
  • halen
    halen Posts: 719
    Very nice!!! Would love to have something like that on one of my camping trips!
    Now if @msg would also do one with a Yeti cooler that also stores ice and beers. Sign me up.
    msg Posts: 10,452
    I'll mass manufacture using Colemans with Yeti stickers, offer unconditional satisfaction, no questions asked, money-back guarantee, return shipping included. Take a bunch of orders with 30 day lead time, ship, then close up shop, and do it all again under a slightly different name!
    That's a great idea, @halen, thanks!
    steveinaz wrote: »
    billbillw wrote: »
    I sorta figured that after looking closer. Have you figured out how long it will play on those 18650s? Also curious if you got the protected style batteries or not.
  • halen
    halen Posts: 719
    billbillw wrote: »
    steveinaz wrote: »
    billbillw wrote: »
    The batteries look bigger than 18650. I would guess 21700 or so with green sleeve likely by Samsung?
  • Jstas
    Jstas Posts: 14,990
    18650's come in many colors, it's not necessarily indicative of the size/type. It's more indicative of the brand and the mAh ratings.
    But if that battery module holds three 18650's, though, then that's a 12v power supply.
    18650's are 3.7 VDC Li-Ion so 3 of them gets you to 11.1VDC, not quite 12v but serviceable for a portable stereo box. Should last a few hours with three 2600 mAh batteries and the t-class amplifiers. They really don't draw that much, especially when you're using efficient drivers.
    And I'm not going to need a big battery either. The kit I have came with 26650 5000mAh Li-ion batteries, five of them. At 3.7VDC each, that's 18.5VDC, plenty of juice to run a 210 watt t-class amplifier circuit for casual listening at the pool or something. Plus, the battery board will run off of an external 21 VDC power supply too.
  • steveinaz
    edited May 2024
    Don't know yet how long the 3 18650's will play, but I've run them so far for about 4.5hrs. I don't think these are the "protected" type, they are Li-Ion--this is actually my first device that uses 18650. I Bought them from Parts Express, along with the battery board.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,276
    Nice job! Would the sound benefit from some damping material added to the enclosure?
  • Jstas
    Jstas Posts: 14,990
    edited May 2024
    I was thinking that too, Ken.
    In fact, I have about 8 pounds of polyfil that I was planning on stuffing in the chambers I make for my box. Was also going to cut some "triangles" to nail/glue into corners to kill standing waves. To build the enclosure effectively, it would end up being cumbersome to move around so any trick I can pull to increase the efficiency while reducing the size of the enclosure will be an overall benefit for portability.
    It won't be ideal but then again, this isn't going to be for critical listening.
    But, with the drivers I got for it, they will show a pretty quick drop under about 70 Hz if they are in a smaller than ideal enclosure. Hence the reason I grabbed the sub. That should reinforce the bottom end so it doesn't sound like an expensive transistor radio.
  • Jstas
    Jstas Posts: 14,990
    Oh, also, if you go out to Parts Express and look at some of the customer submitted projects, a few people lined the inside of plastic ammo boxes with Dynamat to help dampen vibrations.
    I'm planning on building mine out of plywood so I'm not going to worry too much about Dynamatting it.
  • mrbigbluelight
    One shouldn't have to worry sbout portability if one is married. 👍
  • Jstas
    Jstas Posts: 14,990
    Yeah, well, if I made the enclosures for mine to recommended enclosure volume, the enclosures alone would total about 1.5 cubic feet. That's a box that is 18 inches wide by 18 inches tall by 8 inches deep for the internal dimensions. Add an inch and a half in width, depth and height to make up for materials and you're at 19.5 x 19.5 by 9.5. That a sizable and heavy box to walk out to the pool with. Especially when you factor in the materials plus the drivers and electronics. Even worse when the pool is about 600 feet way from your back door. That's a long way to walk in flip flops with 45 pounds of entertainment and still manage to hold on to your beer.
    edited May 2024
    Just make a rolling cart for it. Sound can't be compromised :D
  • halen
    halen Posts: 719
    Okay. 18650 batteries. What size are the speakers? They looked bigger in picture. I may have missed the post somewhere. I read Jstas went into detail about the Lithium Ions.i will not go much into that part. But I have to ask. Do you have a balanced charger for it?
    I would love to build one myself and have as a project with my son.
    I will reach out offline. Will be a fun experience for myself and 5 year old.
    SCompRacer Posts: 9,116
    Nice work Steve!
  • SeleniumFalcon
    A very high caliber build!
    VR3 Posts: 29,461
    I see what you did there
  • steveinaz
    edited May 2024
    It's not ported, so I figured it wouldn't matter. Let me know if that is wrong. The ammo "can" is actually made out of plastic.
