You’re doing it wrong…
^^^ Should have used lag bolts
A 1/4x20 with an 11/32" head would also be acceptable 🔩 🔩Sal Palooza -
Keep tryin' bro'!!! 60 grit should ger 'er done!!!
"Be sure to go over the edges and corners a few extra times."I disabled signatures.
― Aleksandr Solzhenitsyn -
Bruh, you should've seen this young punk over at the MaverickTruckClub who installed a subwoofer inside of a lawn tire and he thought it was great. I'm not lying...
https://www.mavericktruckclub.com/forum/threads/i-put-a-subwoofer-in-a-lawn-tire-and-it-fit.40108/
See profile for rigs. Nothing else here. -
An interesting idea... the "give" of the tire would make for a lossy enclosure... sort of like aperiodic loading (a la Dynaco).
Let's not forget Onkyo's
D-TK10 speaker that had a cabinet designed to resonate.
Design influenced by Japanese guitar maker Takamine and was supposed to enchance ...stuff
You know... the thing 🤔👍
https://vintagesonics.com/reviews/loudspeakers/onkyo-d-tk10-review/
I imagine that if one wanted to that with some pickups, a neck with frets, and some strings, one could have a pretty good DIY box geetar
Sal Palooza -
Daddyjt, I think you are repeating now. I swear we posted that potential Darwin award winning lumberjack already.See profile for rigs. Nothing else here.
Copy - apologies if it’s a repeat. I didn’t recall seeing it here…“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
What the???
Done by one smart cookie.
I guess if the standard junction box don't fit it all, get creative! At least they have proper fittings,See profile for rigs. Nothing else here.
The electric sewing kit.
There are DIY folks who build audio projects in Altoids boxes:
Well. If something fails, they will be the 1st to know
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
SeleniumFalcon wrote: »There are DIY folks who build audio projects in Altoids boxes:
Big difference between high and low voltage though.... (as if you didn't know that).
oops -- misfire.
I'm doing it wrong!
Is that a Neutrik socket?
@xschop and @lightman1 Collaboration; Dreadnought24 Prototype, MKII. MKI was... unsuccessful. Consequently, MKII was tested in a new old workshop.I disabled signatures. -
That's not RFI proof.Don't take experimental gene therapies from known eugenicists.
That's a shame.....
lol. Actual official marketing photo. Seen on the product page here: https://www.crutchfield.com/p_336SPDENRM/Wharfedale-Super-Denton-Red-Mahogany.html?tp=186
That's even more of a shame. Geeez....
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
